Datasheet Wago 891-8992/106-602 — Даташит
Соединительный кабель; Розетка - свободный конец; 2-пол.; длиной 6 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8992/106-705 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
Fire load | 9.65 MJ |
GTIN | 4055143362849 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 2 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 32 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 6 m |
Total number of potentials | 2 |
Type of cable | H05VV-F 2x1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 496.193 г |
Серия: 891 (100 из 1377)
- 891-8992/105-402 891-8992/105-403 891-8992/105-405 891-8992/105-407 891-8992/105-501 891-8992/105-502 891-8992/105-503 891-8992/105-505 891-8992/105-507 891-8992/105-601 891-8992/105-602 891-8992/105-603 891-8992/105-605 891-8992/105-607 891-8992/105-701 891-8992/105-702 891-8992/105-703 891-8992/105-705 891-8992/105-707 891-8992/105-801 891-8992/105-802 891-8992/105-803 891-8992/105-805 891-8992/105-807 891-8992/106-101 891-8992/106-102 891-8992/106-103 891-8992/106-105 891-8992/106-107 891-8992/106-201 891-8992/106-202 891-8992/106-203 891-8992/106-205 891-8992/106-207 891-8992/106-301 891-8992/106-302 891-8992/106-303 891-8992/106-305 891-8992/106-307 891-8992/106-401 891-8992/106-402 891-8992/106-403 891-8992/106-405 891-8992/106-407 891-8992/106-501 891-8992/106-502 891-8992/106-503 891-8992/106-505 891-8992/106-507 891-8992/106-601 891-8992/106-602 891-8992/106-603 891-8992/106-605 891-8992/106-607 891-8992/106-701 891-8992/106-702 891-8992/106-703 891-8992/106-705 891-8992/106-707 891-8992/106-801 891-8992/106-802 891-8992/106-803 891-8992/106-805 891-8992/106-807 891-8992/115-101 891-8992/115-102 891-8992/115-201 891-8992/115-202 891-8992/115-301 891-8992/115-302 891-8992/115-401 891-8992/115-402 891-8992/115-501 891-8992/115-502 891-8992/115-601 891-8992/115-602 891-8992/115-701 891-8992/115-702 891-8992/115-801 891-8992/115-802 891-8992/116-101 891-8992/116-102 891-8992/116-201 891-8992/116-202 891-8992/116-301 891-8992/116-302 891-8992/116-401 891-8992/116-402 891-8992/116-501 891-8992/116-502 891-8992/116-601 891-8992/116-602 891-8992/116-701 891-8992/116-702 891-8992/116-801 891-8992/116-802 891-8992/205-101 891-8992/205-102 891-8992/205-103 891-8992/205-105
8918992/106602, 891 8992/106 602
