Datasheet Wago 891-8992/105-502 — Даташит
Соединительный кабель; Розетка - свободный конец; 2-пол.; длиной 5 м; Кодирование А; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
891-8992/105-705 Wago | по запросу |
Coding | A |
Цвет | white |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
Fire load | 5.818 MJ |
GTIN | 4055143362320 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 2 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 32 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 5 m |
Total number of potentials | 2 |
Type of cable | H05VV-F 2x1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 289.618 г |
Серия: 891 (100 из 1377)
- 891-8992/015-202 891-8992/015-301 891-8992/015-302 891-8992/015-401 891-8992/015-402 891-8992/015-501 891-8992/015-502 891-8992/015-601 891-8992/015-602 891-8992/015-701 891-8992/015-702 891-8992/015-801 891-8992/015-802 891-8992/016-101 891-8992/016-102 891-8992/016-201 891-8992/016-202 891-8992/016-301 891-8992/016-302 891-8992/016-401 891-8992/016-402 891-8992/016-501 891-8992/016-502 891-8992/016-601 891-8992/016-602 891-8992/016-701 891-8992/016-702 891-8992/016-801 891-8992/016-802 891-8992/105-101 891-8992/105-102 891-8992/105-103 891-8992/105-105 891-8992/105-107 891-8992/105-201 891-8992/105-202 891-8992/105-203 891-8992/105-205 891-8992/105-207 891-8992/105-301 891-8992/105-302 891-8992/105-303 891-8992/105-305 891-8992/105-307 891-8992/105-401 891-8992/105-402 891-8992/105-403 891-8992/105-405 891-8992/105-407 891-8992/105-501 891-8992/105-502 891-8992/105-503 891-8992/105-505 891-8992/105-507 891-8992/105-601 891-8992/105-602 891-8992/105-603 891-8992/105-605 891-8992/105-607 891-8992/105-701 891-8992/105-702 891-8992/105-703 891-8992/105-705 891-8992/105-707 891-8992/105-801 891-8992/105-802 891-8992/105-803 891-8992/105-805 891-8992/105-807 891-8992/106-101 891-8992/106-102 891-8992/106-103 891-8992/106-105 891-8992/106-107 891-8992/106-201 891-8992/106-202 891-8992/106-203 891-8992/106-205 891-8992/106-207 891-8992/106-301 891-8992/106-302 891-8992/106-303 891-8992/106-305 891-8992/106-307 891-8992/106-401 891-8992/106-402 891-8992/106-403 891-8992/106-405 891-8992/106-407 891-8992/106-501 891-8992/106-502 891-8992/106-503 891-8992/106-505 891-8992/106-507 891-8992/106-601 891-8992/106-602 891-8992/106-603 891-8992/106-605 891-8992/106-607 891-8992/106-701
8918992/105502, 891 8992/105 502
