Datasheet Wago 890-724 — Даташит
Защелкивающаяся розетка; 4-пол.; Код. A
SNAP-IN SOCKET WHITE | |||
890-724 Wago | по запросу |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | white |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | PL |
Degree of protection | IP20 |
Габариты: глубина | 39.8 mm / 1.567 inch |
Fine-stranded conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 0.75 mm² / 22 … 20 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 20 AWG |
Fire load | 0.167 MJ |
GTIN | 4045454233518 |
Gehäuseblechstärke | 0.5 … 2 mm / 0.02 … 0.079 inch |
Height | 16 mm / 0.63 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | N ⏚ 2|L 1|L' |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Mounting type | Snap-in |
Nominal cross section | 1.5 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 4 |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | N ⏚ 2/L 1/L' |
Product Group | 20 (WINSTA) |
Rated current | 16 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.25 … 1.5 mm² / 22 … 16 AWG |
Solid conductor, push-in termination | 0.75 … 1.5 mm² / 20 … 16 AWG |
Stranded conductor | 0.25 … 1 mm² / 22 … 18 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 4 |
Total number of potentials | 4 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 10.664 г |
Ширина | 28.6 mm / 1.126 inch |
Серия: 890 (100 из 384)
- 890-526 890-527 890-601 890-603 890-604 890-605 890-606 890-615 890-617 890-619 890-620 890-621 890-622 890-623 890-624 890-625 890-626 890-627 890-634 890-636 890-642 890-643 890-644 890-653 890-654 890-655 890-656 890-665 890-671 890-672 890-673 890-674 890-675 890-676 890-677 890-684 890-686 890-692 890-693 890-694 890-702 890-703 890-704 890-705 890-712 890-713 890-714 890-715 890-722 890-723 890-724 890-725 890-725/006-000 890-732 890-733 890-734 890-735 890-742 890-742/060-000 890-743 890-743/060-000 890-743/062-000 890-744 890-744/060-000 890-744/062-000 890-744/064-000 890-745/060-000 890-745/062-000 890-752 890-752/060-000 890-753 890-753/060-000 890-753/062-000 890-754 890-754/060-000 890-754/062-000 890-754/064-000 890-755 890-755/060-000 890-755/062-000 890-762 890-763 890-763/071-000 890-763/073-000 890-764 890-764/071-000 890-764/072-000 890-764/073-000 890-765 890-765/073-000 890-772 890-773 890-773/071-000 890-773/073-000 890-774 890-774/071-000 890-774/072-000 890-774/073-000 890-775/073-000 890-782
