Datasheet Wago 890-212/342-000 — Даташит
Серия890
Модель890-212/342-000
Штекер; с корпусом разгрузки натяжения; 2-пол.; Код. A
6 предложений от 3 поставщиков
PLUG WITH STRAIN RELIEF HOUSING;
Элитан
613 ₽
890-212/342-000
от 747 ₽
Actuation typeOperating tool Push-in
CodingA
Цветblack
Connectable sheathed cable diameter3.8 … 8.2 mm
Country of originDE
Degree of protectionIP20
Габариты: глубина46.5 mm / 1.831 inch
Fine-stranded conductor0.25 … 1.5 mm² / 22 … 16 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule without plastic collar0.25 … 0.75 mm² / 22 … 20 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 20 AWG
GTIN4055143463638
Height13.2 mm / 0.52 inch
Locking leverнет
MarkingL N
Mismating protectionYes
Nominal cross section1.5 mm²
Note (strip length)see also packaging or instructions
Number of Poles2
Potential markingL N
Rated current16 A
Rated voltage (III / 3)250 В
Solid conductor0.25 … 1.5 mm² / 22 … 16 AWG
Solid conductor, push-in termination0.75 … 1.5 mm² / 20 … 16 AWG
Strain reliefStrain relief housing
Stranded conductor0.25 … 1 mm² / 22 … 18 AWG
Strip length17.5 мм
Total number of connection points2
Total number of potentials2
Вес4.564 г
Ширина15.6 mm / 0.614 inch
890212/342000, 890 212/342 000
На английском языке: Datasheet Wago 890-212/342-000
