Datasheet Wago 771-9973/107-702 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 3-пол.; Код. P; H05VV-F 3G 2,5 мм²; 7 m
771-9973/017-501 Wago | по запросу |
Coding | P |
Цвет | red |
Color of sheathed cable | white |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | red |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 2.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 9.2 … 11.4 mm |
Fire load | 18.764 MJ |
GTIN | 4045454523251 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | L ⏚ N |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 3 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | L ⏚ N |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | black |
Rated current | 20 A |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | white |
Strip length | 55 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 7 m |
Total number of potentials | 3 |
Type of cable | H05VV-F 3G2.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 1129.174 г |
Серия: 771 (100 из 3186)
- 771-9973/016-702 771-9973/016-705 771-9973/016-801 771-9973/016-802 771-9973/016-805 771-9973/017-101 771-9973/017-102 771-9973/017-201 771-9973/017-202 771-9973/017-301 771-9973/017-302 771-9973/017-401 771-9973/017-402 771-9973/017-501 771-9973/017-502 771-9973/017-601 771-9973/017-602 771-9973/017-701 771-9973/017-702 771-9973/017-801 771-9973/017-802 771-9973/106-101 771-9973/106-102 771-9973/106-201 771-9973/106-202 771-9973/106-301 771-9973/106-302 771-9973/106-401 771-9973/106-402 771-9973/106-501 771-9973/106-502 771-9973/106-601 771-9973/106-602 771-9973/106-701 771-9973/106-702 771-9973/106-801 771-9973/106-802 771-9973/107-101 771-9973/107-102 771-9973/107-201 771-9973/107-202 771-9973/107-301 771-9973/107-302 771-9973/107-401 771-9973/107-402 771-9973/107-501 771-9973/107-502 771-9973/107-601 771-9973/107-602 771-9973/107-701 771-9973/107-702 771-9973/107-801 771-9973/107-802 771-9973/116-101 771-9973/116-102 771-9973/116-201 771-9973/116-202 771-9973/116-301 771-9973/116-302 771-9973/116-401 771-9973/116-402 771-9973/116-501 771-9973/116-502 771-9973/116-601 771-9973/116-602 771-9973/116-701 771-9973/116-702 771-9973/116-801 771-9973/116-802 771-9973/117-101 771-9973/117-102 771-9973/117-201 771-9973/117-202 771-9973/117-301 771-9973/117-302 771-9973/117-401 771-9973/117-402 771-9973/117-501 771-9973/117-502 771-9973/117-601 771-9973/117-602 771-9973/117-701 771-9973/117-702 771-9973/117-801 771-9973/117-802 771-9973/206-101 771-9973/206-102 771-9973/206-104 771-9973/206-105 771-9973/206-201 771-9973/206-202 771-9973/206-204 771-9973/206-205 771-9973/206-301 771-9973/206-302 771-9973/206-304 771-9973/206-305 771-9973/206-401 771-9973/206-402 771-9973/206-404
7719973/107702, 771 9973/107 702
