Datasheet Wago 771-8995/108-201 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 5-пол.; Код. A; H05VV-F 5G 4,0 мм²; 2 м
771-8995/218-501 Wago | по запросу |
Coding | A |
Цвет | black |
Color of sheathed cable | black |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | black |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 4 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 13 … 16.1 mm |
Fire load | 10.89 MJ |
GTIN | 4050821449461 |
Ground function | with preceding GND contact |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ L1 L2 L3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 5 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | N ⏚ L1 L2 L3 |
Printing color of mating face | white |
Printing color of sheathed cable | white |
Printing color of strain relief | white |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Reaction to fire class per EN 50575 | Eca |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 55 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 2 m |
Total number of potentials | 5 |
Type of cable | H05VV-F 5G4 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 753.77 г |
Серия: 771 (100 из 3186)
- 771-8994/106-507 771-8994/107-103 771-8994/107-105 771-8994/107-107 771-8994/107-303 771-8994/107-305 771-8994/107-307 771-8994/107-503 771-8994/107-505 771-8994/107-507 771-8994/206-105 771-8994/206-107 771-8994/206-303 771-8994/206-305 771-8994/206-307 771-8994/206-503 771-8994/206-505 771-8994/206-507 771-8994/207-303 771-8994/207-503 771-8995/006-103 771-8995/006-105 771-8995/006-107 771-8995/006-303 771-8995/006-305 771-8995/006-307 771-8995/006-503 771-8995/006-505 771-8995/006-507 771-8995/007-303 771-8995/008-101 771-8995/008-201 771-8995/008-301 771-8995/008-401 771-8995/008-501 771-8995/008-601 771-8995/008-701 771-8995/008-801 771-8995/018-101 771-8995/018-201 771-8995/018-301 771-8995/018-401 771-8995/018-501 771-8995/018-601 771-8995/018-701 771-8995/018-801 771-8995/106-103 771-8995/106-303 771-8995/106-503 771-8995/108-101 771-8995/108-201 771-8995/108-301 771-8995/108-401 771-8995/108-501 771-8995/108-601 771-8995/108-701 771-8995/108-801 771-8995/118-101 771-8995/118-201 771-8995/118-301 771-8995/118-401 771-8995/118-501 771-8995/118-601 771-8995/118-701 771-8995/118-801 771-8995/206-103 771-8995/206-105 771-8995/206-303 771-8995/206-503 771-8995/207-303 771-8995/208-101 771-8995/208-201 771-8995/208-301 771-8995/208-401 771-8995/208-501 771-8995/208-601 771-8995/208-701 771-8995/208-801 771-8995/218-101 771-8995/218-201 771-8995/218-301 771-8995/218-401 771-8995/218-501 771-8995/218-601 771-8995/218-701 771-8995/218-801 771-9273/016-205 771-9273/016-305 771-9273/016-405 771-9273/016-505 771-9273/016-605 771-9273/016-805 771-9273/216-105 771-9273/216-205 771-9285/016-101 771-9285/016-201 771-9285/016-301 771-9285/016-401 771-9285/016-501 771-9285/016-601
7718995/108201, 771 8995/108 201
