Datasheet Wago 771-8994/107-103 — Даташит
Соединительный кабель; Розетка - свободный конец; 4-пол.; длиной 1 м; Кодирование B; с изоляцией из ПВХ; Концы проводников, припаянные: 9 мм
771-8994/007-105 Wago | по запросу |
Coding | B |
Цвет | gray |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | gray |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 2.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 10.1 … 12.5 mm |
Fire load | 2.967 MJ |
GTIN | 4050821621409 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 3 4 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 4 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 2 3 4 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 20 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 55 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 1 m |
Total number of potentials | 4 |
Type of cable | Control line 4 x 2.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 200.284 г |
Серия: 771 (100 из 3186)
- 771-8992/216-601 771-8992/216-602 771-8992/216-701 771-8992/216-702 771-8992/216-801 771-8992/216-802 771-8992/217-101 771-8992/217-102 771-8992/217-201 771-8992/217-202 771-8992/217-301 771-8992/217-302 771-8992/217-401 771-8992/217-402 771-8992/217-501 771-8992/217-502 771-8992/217-601 771-8992/217-602 771-8992/217-701 771-8992/217-702 771-8992/217-801 771-8992/217-802 771-8993/1004-051 771-8994/006-103 771-8994/006-105 771-8994/006-107 771-8994/006-303 771-8994/006-305 771-8994/006-307 771-8994/006-503 771-8994/006-505 771-8994/006-507 771-8994/007-103 771-8994/007-105 771-8994/007-107 771-8994/007-303 771-8994/007-305 771-8994/007-307 771-8994/007-503 771-8994/007-505 771-8994/007-507 771-8994/106-103 771-8994/106-105 771-8994/106-107 771-8994/106-303 771-8994/106-305 771-8994/106-307 771-8994/106-503 771-8994/106-505 771-8994/106-507 771-8994/107-103 771-8994/107-105 771-8994/107-107 771-8994/107-303 771-8994/107-305 771-8994/107-307 771-8994/107-503 771-8994/107-505 771-8994/107-507 771-8994/206-105 771-8994/206-107 771-8994/206-303 771-8994/206-305 771-8994/206-307 771-8994/206-503 771-8994/206-505 771-8994/206-507 771-8994/207-303 771-8994/207-503 771-8995/006-103 771-8995/006-105 771-8995/006-107 771-8995/006-303 771-8995/006-305 771-8995/006-307 771-8995/006-503 771-8995/006-505 771-8995/006-507 771-8995/007-303 771-8995/008-101 771-8995/008-201 771-8995/008-301 771-8995/008-401 771-8995/008-501 771-8995/008-601 771-8995/008-701 771-8995/008-801 771-8995/018-101 771-8995/018-201 771-8995/018-301 771-8995/018-401 771-8995/018-501 771-8995/018-601 771-8995/018-701 771-8995/018-801 771-8995/106-103 771-8995/106-303 771-8995/106-503 771-8995/108-101 771-8995/108-201
7718994/107103, 771 8994/107 103
