Datasheet Wago 771-8992/205-503 — Даташит
предв. собранный соединительный кабель; Штекер/открытый; 2-пол.; Код. B; Контрольный кабель 2 x 1,0 мм²; 5 м
771-8992/205-703 Wago | по запросу |
Coding | B |
Цвет | gray |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | gray |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 5.9 … 7.5 mm |
GTIN | 4055143486811 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 2 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 2 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 10 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 35 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 5 m |
Total number of potentials | 2 |
Type of cable | Control line 2 x 1 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 250 г |
Серия: 771 (100 из 3186)
- 771-8992/107-601 771-8992/107-602 771-8992/107-701 771-8992/107-702 771-8992/107-801 771-8992/107-802 771-8992/116-101 771-8992/116-102 771-8992/116-201 771-8992/116-202 771-8992/116-301 771-8992/116-302 771-8992/116-401 771-8992/116-402 771-8992/116-501 771-8992/116-502 771-8992/116-601 771-8992/116-602 771-8992/116-701 771-8992/116-702 771-8992/116-801 771-8992/116-802 771-8992/117-101 771-8992/117-102 771-8992/117-201 771-8992/117-202 771-8992/117-301 771-8992/117-302 771-8992/117-401 771-8992/117-402 771-8992/117-501 771-8992/117-502 771-8992/117-601 771-8992/117-602 771-8992/117-701 771-8992/117-702 771-8992/117-801 771-8992/117-802 771-8992/205-103 771-8992/205-105 771-8992/205-107 771-8992/205-203 771-8992/205-205 771-8992/205-207 771-8992/205-303 771-8992/205-305 771-8992/205-307 771-8992/205-403 771-8992/205-405 771-8992/205-407 771-8992/205-503 771-8992/205-505 771-8992/205-507 771-8992/205-603 771-8992/205-605 771-8992/205-607 771-8992/205-703 771-8992/205-705 771-8992/205-803 771-8992/205-805 771-8992/206-101 771-8992/206-102 771-8992/206-103 771-8992/206-105 771-8992/206-107 771-8992/206-201 771-8992/206-202 771-8992/206-203 771-8992/206-205 771-8992/206-207 771-8992/206-301 771-8992/206-302 771-8992/206-303 771-8992/206-305 771-8992/206-307 771-8992/206-401 771-8992/206-402 771-8992/206-403 771-8992/206-405 771-8992/206-407 771-8992/206-501 771-8992/206-502 771-8992/206-503 771-8992/206-505 771-8992/206-507 771-8992/206-601 771-8992/206-602 771-8992/206-603 771-8992/206-605 771-8992/206-607 771-8992/206-701 771-8992/206-702 771-8992/206-703 771-8992/206-705 771-8992/206-707 771-8992/206-801 771-8992/206-802 771-8992/206-803 771-8992/206-805 771-8992/206-807
7718992/205503, 771 8992/205 503
