Datasheet Wago 771-8992/106-407 — Даташит
предв. собранный соединительный кабель; Eca; Розетка/открытая; 2-пол.; Код. B; Контрольный кабель 2 x 1,5 мм²; 4m
771-8992/106-803 Wago | по запросу |
Coding | B |
Цвет | pink |
Color of sheathed cable | gray |
Conductor preparation | tip-bonded |
Connection type | Socket - free end |
Connector color | pink |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 6.8 … 8.6 mm |
GTIN | 4055143502665 |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | 1 2 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 2 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | 1 2 |
Printing color of mating face | black |
Printing color of sheathed cable | black |
Printing color of strain relief | white |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Sheath material | PVC |
Strain relief color | black |
Strip length | 35 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total length | 4 m |
Total number of potentials | 2 |
Type of cable | Control line 2 x 1.5 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 271.807 г |
Серия: 771 (100 из 3186)
- 771-8992/017-502 771-8992/017-601 771-8992/017-602 771-8992/017-701 771-8992/017-702 771-8992/017-801 771-8992/017-802 771-8992/105-103 771-8992/105-105 771-8992/105-107 771-8992/105-203 771-8992/105-205 771-8992/105-207 771-8992/105-303 771-8992/105-305 771-8992/105-307 771-8992/105-403 771-8992/105-405 771-8992/105-407 771-8992/105-503 771-8992/105-505 771-8992/105-507 771-8992/105-603 771-8992/105-605 771-8992/105-607 771-8992/105-703 771-8992/105-705 771-8992/105-707 771-8992/105-803 771-8992/105-805 771-8992/105-807 771-8992/106-101 771-8992/106-102 771-8992/106-103 771-8992/106-105 771-8992/106-107 771-8992/106-201 771-8992/106-202 771-8992/106-203 771-8992/106-205 771-8992/106-207 771-8992/106-301 771-8992/106-302 771-8992/106-303 771-8992/106-305 771-8992/106-307 771-8992/106-401 771-8992/106-402 771-8992/106-403 771-8992/106-405 771-8992/106-407 771-8992/106-501 771-8992/106-502 771-8992/106-503 771-8992/106-505 771-8992/106-507 771-8992/106-601 771-8992/106-602 771-8992/106-603 771-8992/106-605 771-8992/106-607 771-8992/106-701 771-8992/106-702 771-8992/106-703 771-8992/106-705 771-8992/106-707 771-8992/106-801 771-8992/106-802 771-8992/106-803 771-8992/106-805 771-8992/106-807 771-8992/107-101 771-8992/107-102 771-8992/107-201 771-8992/107-202 771-8992/107-301 771-8992/107-302 771-8992/107-401 771-8992/107-402 771-8992/107-501 771-8992/107-502 771-8992/107-601 771-8992/107-602 771-8992/107-701 771-8992/107-702 771-8992/107-801 771-8992/107-802 771-8992/116-101 771-8992/116-102 771-8992/116-201 771-8992/116-202 771-8992/116-301 771-8992/116-302 771-8992/116-401 771-8992/116-402 771-8992/116-501 771-8992/116-502 771-8992/116-601 771-8992/116-602 771-8992/116-701
7718992/106407, 771 8992/106 407
