Datasheet Wago 771-5001/195-000 — Даташит
предварительно собранный соединительный кабель; B2ca; вилка/открытый конец; 5-полюсный; Код I; H05Z1Z1-F 3G 1,5 мм²; 7 м
Счётчик горячей и холодной воды Декаст СТВУ 77-150-01 используется для измерения суммарного расхода горячей и холодной питьевой и сетевой воды в... | |||
СТВУ 77-150-01 | 54 980 ₽ | ||
771-5001/186-000 Wago | по запросу |
Coding | I |
Цвет | blue |
Conductor preparation | tip-bonded |
Connection type | Plug - free end |
Connector color | blue |
Contact material | Copper or copper alloy, surface-treated |
Continuous operating temperature | −35 … +85 °C |
Country of origin | DE |
Cross section of single conductor | 1.5 mm² |
Degree of protection | IP20 |
Durchmesser der Mantelleitung | 7.4 … 9.4 mm |
GTIN | 4055143807401 |
Ground function | with preceding GND contact |
Halogen-free | Yes |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Note on Continuous Service Temperature | PVC cable for temperatures ≤ 70 °C (including halogen-free)Insulating parts for temperatures ≤ 105 °C |
Note on Protection Type | Only in mated condition with strain relief housing (These compact connectors are not designed for use in open, easily accessible areas) |
Number of Poles | 3 |
Packaging type | not packed |
Pin spacing | 10 mm (0.394 inch) |
Processing temperature | -5 … +40 °C |
Rated voltage (III / 3) | 250 В |
Reaction to fire class per EN 50575 | B2ca |
Retention force of a plug-in connection | when locked: > 80N |
Strip length | 48 мм |
Total length | 7 m |
Total number of potentials | 3 |
Type of cable assembly | Connecting cable |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 735.224 г |
Серия: 771 (100 из 3186)
- 771-5001/100-000 771-5001/106-000 771-5001/107-000 771-5001/110-000 771-5001/131-000 771-5001/132-000 771-5001/148-000 771-5001/149-000 771-5001/150-000 771-5001/151-000 771-5001/152-000 771-5001/153-000 771-5001/154-000 771-5001/155-000 771-5001/156-000 771-5001/157-000 771-5001/158-000 771-5001/159-000 771-5001/160-000 771-5001/161-000 771-5001/162-000 771-5001/163-000 771-5001/164-000 771-5001/165-000 771-5001/166-000 771-5001/167-000 771-5001/168-000 771-5001/169-000 771-5001/170-000 771-5001/171-000 771-5001/172-000 771-5001/173-000 771-5001/174-000 771-5001/175-000 771-5001/176-000 771-5001/177-000 771-5001/178-000 771-5001/179-000 771-5001/180-000 771-5001/181-000 771-5001/182-000 771-5001/183-000 771-5001/185-000 771-5001/186-000 771-5001/189-000 771-5001/190-000 771-5001/191-000 771-5001/192-000 771-5001/193-000 771-5001/194-000 771-5001/195-000 771-5001/196-000 771-5001/197-000 771-5001/198-000 771-5001/199-000 771-5001/200-000 771-5001/201-000 771-5001/202-000 771-5001/203-000 771-5001/204-000 771-5001/205-000 771-5001/206-000 771-5001/207-000 771-5001/208-000 771-5001/209-000 771-5001/210-000 771-5001/211-000 771-5001/212-000 771-5001/213-000 771-5001/214-000 771-5001/215-000 771-5001/216-000 771-5001/217-000 771-5001/218-000 771-5001/219-000 771-5001/220-000 771-5001/221-000 771-5001/222-000 771-5001/223-000 771-5001/224-000 771-6993/006-101 771-6993/006-102 771-6993/006-201 771-6993/006-202 771-6993/006-301 771-6993/006-302 771-6993/006-401 771-6993/006-402 771-6993/006-501 771-6993/006-502 771-6993/006-601 771-6993/006-602 771-6993/006-701 771-6993/006-702 771-6993/006-801 771-6993/006-802 771-6993/007-101 771-6993/007-102 771-6993/007-201 771-6993/007-202
7715001/195000, 771 5001/195 000
