Datasheet Wago 770-335 — Даташит
Штекер; с корпусом разгрузки натяжения; 5-пол.; Код. A
22 предложений от 10 поставщиков Разъемы, Соединители Прямоугольные разъемы - Корпуса | |||
770335-1 TE Connectivity | от 42 ₽ | ||
770335-1 TE Connectivity | 52 ₽ | ||
770335-1 TE Connectivity | 58 ₽ |
Actuation type | Operating tool Push-in |
Coding | A |
Цвет | white |
Connectable sheathed cable diameter | 9 … 13 mm |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 75.9 mm / 2.988 inch |
Fine-stranded conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² / 20 … 16 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² / 20 … 14 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
Fire load | 0.679 MJ |
GTIN | 4044918254700 |
Ground function | with preceding GND contact |
Height | 17 mm / 0.669 inch |
Locking lever | нет |
Locking of plug-in connection | locking lever |
Marking | N ⏚ L1 L2 L3 |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Nominal cross section | 4 mm² |
Note (strip length) | see also packaging or instructions |
Number of Poles | 5 |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | N ⏚ L1 L2 L3 |
Product Group | 20 (WINSTA) |
Rated current | 25 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solid conductor | 0.5 … 4 mm² / 20 … 12 AWG |
Solid conductor, push-in termination | 1.5 … 4 mm² / 16 … 12 AWG |
Strain relief | Strain relief housing |
Stranded conductor | 0.5 … 2.5 mm² / 20 … 14 AWG |
Strip length | 9 mm / 0.35 Inch |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of connection points | 5 |
Total number of potentials | 5 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 29.594 г |
Ширина | 54.6 mm / 2.15 inch |
Серия: 770 (100 из 608)
- 770-264 770-264/071-000 770-264/072-000 770-264/073-000 770-265 770-265/073-000 770-272 770-273 770-273/071-000 770-273/073-000 770-274 770-274/071-000 770-274/072-000 770-274/073-000 770-275 770-275/073-000 770-282 770-282/080-000 770-282/082-000 770-283 770-283/081-000 770-283/082-000 770-284 770-284/081-000 770-285 770-285/080-000 770-285/082-000 770-292 770-292/080-000 770-292/082-000 770-293 770-293/081-000 770-293/082-000 770-294 770-294/081-000 770-295 770-295/080-000 770-295/082-000 770-305 770-3105 770-3105/011-000 770-3115 770-3115/011-000 770-315 770-317 770-318 770-319 770-320 770-321 770-325 770-335 770-337 770-338 770-339 770-340 770-341 770-354 770-360 770-382 770-383 770-401 770-405 770-408 770-415 770-418 770-425 770-428 770-435 770-438 770-450 770-450/000-001 770-450/000-002 770-450/000-005 770-450/000-006 770-450/000-012 770-5001/100-000 770-502/041-000 770-502/042-000 770-503 770-503/021-000 770-503/023-000 770-503/032-000 770-503/035-000 770-503/038-000 770-504 770-504/023-000 770-505 770-505/021-000 770-505/023-000 770-506/029-000 770-507/047-000 770-512/041-000 770-512/042-000 770-513 770-513/021-000 770-513/023-000 770-513/032-000 770-513/035-000 770-513/038-000 770-514
