Datasheet Wago 769-611/001-000 — Даташит
1-проводная вилка; Монтажные ножки; 4 mm²; Шаг контактов 5 мм; 11-пол.
1-CONDUCTOR MALE CONNECTOR; SNAP | |||
769-611/001-000 Wago | по запросу |
Цвет | gray |
Connectable conductor materials | Copper Aluminum |
Country of origin | PL |
Габариты: глубина | 40.2 mm / 1.583 inch |
Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Fire load | 0.633 MJ |
GTIN | 4044918522144 |
Height from the surface | 18.3 mm / 0.72 inch |
Mounting type | Snap-in mounting foot |
Nominal cross section | 4 mm² |
Number of Poles | 11 |
Pin spacing | 5 mm / 0.197 inch |
Product Group | 18 (X-COM-System) |
Rated current | 32 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 11 |
Total number of potentials | 11 |
Type of wiring | Front-entry wiring |
Вес | 32.069 г |
Ширина | 58.6 mm / 2.307 inch |
Серия: 769 (100 из 460)
- 769-602/006-000 769-603 769-603/001-000 769-603/002-000 769-603/004-000 769-603/005-000 769-603/006-000 769-604 769-604/001-000 769-604/002-000 769-604/004-000 769-604/005-000 769-604/006-000 769-605 769-605/001-000 769-605/002-000 769-605/004-000 769-605/005-000 769-605/006-000 769-606 769-606/001-000 769-606/002-000 769-606/004-000 769-606/005-000 769-606/006-000 769-607 769-607/001-000 769-607/002-000 769-607/004-000 769-607/005-000 769-607/006-000 769-608 769-608/001-000 769-608/002-000 769-608/004-000 769-608/005-000 769-608/006-000 769-609 769-609/001-000 769-609/002-000 769-609/004-000 769-609/005-000 769-609/006-000 769-610 769-610/001-000 769-610/002-000 769-610/004-000 769-610/005-000 769-610/006-000 769-611 769-611/001-000 769-611/002-000 769-611/004-000 769-611/005-000 769-611/006-000 769-612 769-612/001-000 769-612/002-000 769-612/004-000 769-612/005-000 769-612/006-000 769-613 769-613/001-000 769-613/002-000 769-613/004-000 769-613/005-000 769-613/006-000 769-614 769-614/001-000 769-614/002-000 769-614/004-000 769-614/005-000 769-614/006-000 769-615 769-615/001-000 769-615/002-000 769-615/004-000 769-615/005-000 769-615/006-000 769-632 769-632/000-036 769-632/003-000 769-632/003-036 769-632/004-000 769-632/007-000 769-633 769-633/000-036 769-633/003-000 769-633/003-036 769-633/004-000 769-633/007-000 769-634 769-634/000-036 769-634/003-000 769-634/003-036 769-634/004-000 769-634/007-000 769-635 769-635/000-036 769-635/003-000
769611/001000, 769 611/001 000
