Datasheet Wago 2734-103 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Нажимная кнопка; 1,5; Шаг контактов 3,5 мм; 3-пол.
HEADER MALE R/A 3POS | |||
2734-103 Wago | 973 ₽ | ||
2734-103/031-000 Wago | по запросу |
Actuation type | Push-button |
Цвет | light gray |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 20.4 mm / 0.803 inch |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.054 MJ |
GTIN | 4045454696313 |
Height | 13.5 mm / 0.531 inch |
Material group | I |
Mismating protection | Yes |
Number of Poles | 3 |
Number of levels | 1 |
Rated current | 10 A |
Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Вес | 2.758 г |
Ширина | 12.6 mm / 0.496 inch |
Серия: 2734 (100 из 121)
- 2734-102 2734-102/031-000 2734-102/037-000 2734-102/107-000 2734-103 2734-103/031-000 2734-103/037-000 2734-103/107-000 2734-104 2734-104/031-000 2734-104/033-000 2734-104/037-000 2734-104/107-000 2734-105 2734-105/031-000 2734-105/037-000 2734-105/107-000 2734-106 2734-106/031-000 2734-106/033-000 2734-106/037-000 2734-106/107-000 2734-107 2734-107/031-000 2734-107/037-000 2734-107/107-000 2734-108 2734-108/031-000 2734-108/037-000 2734-108/107-000 2734-109 2734-109/031-000 2734-109/037-000 2734-109/107-000 2734-110 2734-110/027-000 2734-110/037-000 2734-110/107-000 2734-111 2734-111/027-000 2734-111/037-000 2734-111/107-000 2734-112 2734-112/027-000 2734-112/031-000 2734-112/037-000 2734-112/107-000 2734-113 2734-113/027-000 2734-113/037-000 2734-113/107-000 2734-114 2734-114/027-000 2734-114/037-000 2734-114/107-000 2734-116 2734-116/027-000 2734-116/037-000 2734-116/107-000 2734-118 2734-118/027-000 2734-118/037-000 2734-118/107-000 2734-120 2734-120/027-000 2734-120/037-000 2734-120/107-000 2734-124 2734-124/027-000 2734-124/037-000 2734-124/107-000 2734-202 2734-202/031-000 2734-202/037-000 2734-203 2734-203/031-000 2734-203/037-000 2734-204 2734-204/031-000 2734-204/037-000 2734-205 2734-205/031-000 2734-205/037-000 2734-206 2734-206/031-000 2734-206/037-000 2734-208 2734-208/031-000 2734-208/037-000 2734-209 2734-209/031-000 2734-209/037-000 2734-210 2734-210/027-000 2734-210/031-000 2734-210/037-000 2734-212 2734-212/027-000 2734-212/031-000 2734-212/037-000
2734103, 2734 103
