Datasheet Wago 2706-311 — Даташит
Серия2706
Модель2706-311
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 12,5 мм; 11-полюсный; CAGE CLAMP
Actuation typeLever
Цветgray
Conductor entry angle to the PCB30 °
Contact platingtin-plated
Country of originPL
Габариты: глубина26 mm / 1.024 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.5 … 6 mm² / 20 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.5 … 6 mm²
Fire load1.605 MJ
GTIN4050821093534
Height30 mm / 1.181 inch
Height from the surface25.5 mm / 1.004 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing12.5 mm (0.492 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.5 … 6 mm² / 20 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points11
Total number of potentials11
Вес76.167 г
Ширина132.5 mm / 5.217 inch
  • PCB Interconnect
2706311, 2706 311
На английском языке: Datasheet Wago 2706-311
