Datasheet Wago 2626-3107/020-000 — Даташит
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 7,5 мм; 7-полюсный; Зажим Push-in CAGE CLAMP
PCB TERMINAL BLOCK; 6 MM; PIN SP | |||
2626-3107/020-000 Wago | по запросу |
Цвет | gray |
Conductor entry angle to the PCB | 90 ° |
Country of origin | DE |
Габариты: глубина | 18.5 mm / 0.728 inch |
Drilled hole diameter (tolerance) | 2(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 10 mm² / 24 … 8 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 6 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 6 mm² |
Fine-stranded conductor, with twin ferrule | 0.25 … 2.5 mm² |
GTIN | 4055143587358 |
Height | 28.2 mm / 1.11 inch |
Height from the surface | 24.2 mm / 0.953 inch |
Material group | I |
Number of Poles | 7 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 1.5 x 1 mm |
Solder pin length | 4 мм |
Solid conductor | 0.2 … 10 mm² / 24 … 8 AWG |
Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
Total number of connection points | 7 |
Total number of potentials | 7 |
Type of mounting | Feed-through mounting |
Вес | 26.618 г |
Ширина | 54.3 mm / 2.138 inch |
Серия: 2626 (32)
- 2626-1101 2626-1102/020-000 2626-1103/020-000 2626-1103/020-004 2626-1104/020-000 2626-1104/020-004 2626-1105/020-000 2626-1105/020-004 2626-1106/020-000 2626-1107/020-000 2626-1108/020-000 2626-1109/020-000 2626-1110/020-000 2626-1111/020-000 2626-1112/020-000 2626-3101 2626-3102 2626-3102/020-000 2626-3103 2626-3103/020-000 2626-3104 2626-3104/020-000 2626-3105/020-000 2626-3105/020-004 2626-3106/020-000 2626-3107/020-000 2626-3108/020-000 2626-3109/020-000 2626-3110/020-000 2626-3111/020-000 2626-3112/020-000 2626-3452
- PCB Interconnect
26263107/020000, 2626 3107/020 000
