Datasheet Wago 2624-3307 — Даташит
Серия2624
Модель2624-3307
Клеммная колодка для печатной платы; 4 мм²; Шаг контактов 7,5 мм; 7-полюсный; Зажим Push-in CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originDE
Габариты: глубина16.3 mm / 0.642 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fine-stranded conductor, with twin ferrule0.25 … 1.5 mm²
Fire load0.208 MJ
GTIN4055143582568
Height20.3 mm / 0.799 inch
Height from the surface16.3 mm / 0.642 inch
Material groupI
Number of Poles7
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)630 В
Solder pin dimensions0.8 x 1 mm
Solder pin length4 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points7
Total number of potentials7
Type of mountingFeed-through mounting
Вес13.168 г
Ширина51.5 mm / 2.028 inch
  • PCB Interconnect
26243307, 2624 3307
На английском языке: Datasheet Wago 2624-3307
