Datasheet Wago 2606-3108/020-000 — Даташит
Серия2606
Модель2606-3108/020-000
Клеммная колодка для печатной платы; рычаг; 6 мм²; Шаг контактов 7,5 мм; 8-полюсный; Зажим Push-in CAGE CLAMP
2606-3108/020-000
Actuating element colororange
Actuation typeLever
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originDE
Габариты: глубина24 mm / 0.945 inch
Drilled hole diameter (tolerance)2(+ 0.1) мм
Fine-stranded conductor0.2 … 10 mm² / 24 … 8 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 6 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 6 mm²
Fine-stranded conductor, with twin ferrule0.25 … 2.5 mm²
GTIN4055143586689
Height31 mm / 1.22 inch
Height from the surface27 mm / 1.063 inch
Material groupI
Number of Poles8
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)800 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions1.5 x 1.2 mm
Solder pin length4 мм
Solid conductor0.2 … 10 mm² / 24 … 8 AWG
Strip length11 … 13 mm / 0.43 … 0.51 Inch
Total number of connection points8
Total number of potentials8
Вес33.452 г
Ширина62.85 mm / 2.474 inch
  • PCB Interconnect
26063108/020000, 2606 3108/020 000
На английском языке: Datasheet Wago 2606-3108/020-000
