Datasheet Wago 2604-3311 — Даташит
Серия2604
Модель2604-3311
Клеммная колодка для печатной платы; рычаг; 4 мм²; Шаг контактов 7,5 мм; 11-полюсный; Зажим Push-in CAGE CLAMP
Actuating element colororange
Actuation typeLever
Цветgray
Conductor entry angle to the PCB90 °
Contact platingtin-plated
Country of originDE
Габариты: глубина16.7 mm / 0.657 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fine-stranded conductor0.2 … 4 mm² / 24 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fine-stranded conductor, with twin ferrule0.25 … 1.5 mm²
GTIN4055143564953
Height25.3 mm / 0.996 inch
Height from the surface21.3 mm / 0.839 inch
Material groupI
Number of Poles11
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current32 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)630 В
Solder pin dimensions0.8 x 1 mm
Solder pin length4 мм
Solid conductor0.2 … 4 mm² / 24 … 12 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points11
Total number of potentials11
Вес22.19 г
Ширина82.4 mm / 3.244 inch
  • PCB Interconnect
26043311, 2604 3311
На английском языке: Datasheet Wago 2604-3311
