Datasheet Wago 2231-318/031-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; зажимное кольцо; 2,5 мм²; Шаг контактов 5,08 мм; 18-пол.
1-CONDUCTOR FEMALE PLUG; PUSH-BU | |||
2231-318/102-000 Wago | по запросу |
Actuation type | Push-button |
Цвет | orange |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 25.6 mm / 1.008 inch |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.604 MJ |
GTIN | 4045454872687 |
Height | 15 mm / 0.591 inch |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 18 |
Number of levels | 1 |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
Total number of connection points | 18 |
Total number of potentials | 18 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 29.144 г |
Ширина | 106.24 mm / 4.183 inch |
Серия: 2231 (100 из 343)
- 2231-309/037-000 2231-309/102-000 2231-309/107-000 2231-310/008-000 2231-310/026-000 2231-310/031-000 2231-310/037-000 2231-310/102-000 2231-310/107-000 2231-311/008-000 2231-311/026-000 2231-311/031-000 2231-311/037-000 2231-311/102-000 2231-312/008-000 2231-312/026-000 2231-312/031-000 2231-312/037-000 2231-312/102-000 2231-312/107-000 2231-313/008-000 2231-313/026-000 2231-313/031-000 2231-313/037-000 2231-313/102-000 2231-314/008-000 2231-314/026-000 2231-314/031-000 2231-314/037-000 2231-314/102-000 2231-314/107-000 2231-315/008-000 2231-315/026-000 2231-315/031-000 2231-315/037-000 2231-315/102-000 2231-315/107-000 2231-316/008-000 2231-316/026-000 2231-316/031-000 2231-316/037-000 2231-316/102-000 2231-316/107-000 2231-317/008-000 2231-317/026-000 2231-317/031-000 2231-317/037-000 2231-317/102-000 2231-318/008-000 2231-318/026-000 2231-318/031-000 2231-318/037-000 2231-318/102-000 2231-319/008-000 2231-319/026-000 2231-319/031-000 2231-319/037-000 2231-319/102-000 2231-320/008-000 2231-320/026-000 2231-320/031-000 2231-320/037-000 2231-320/102-000 2231-321/008-000 2231-321/026-000 2231-321/031-000 2231-321/037-000 2231-321/102-000 2231-322/008-000 2231-322/026-000 2231-322/031-000 2231-322/037-000 2231-322/102-000 2231-323/008-000 2231-323/026-000 2231-323/031-000 2231-323/037-000 2231-323/102-000 2231-324/008-000 2231-324/026-000 2231-324/031-000 2231-324/037-000 2231-324/102-000 2231-702/008-000 2231-702/026-000 2231-702/031-000 2231-702/037-000 2231-703/008-000 2231-703/026-000 2231-703/026-000/133-000 2231-703/031-000 2231-703/037-000 2231-704/008-000 2231-704/026-000 2231-704/031-000 2231-704/037-000 2231-705/008-000 2231-705/026-000 2231-705/031-000 2231-705/037-000
2231318/031000, 2231 318/031 000
