Datasheet Wago 2231-209/031-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; зажимное кольцо; 2,5 мм²; Шаг контактов 7,5 мм; 9-пол.
223-1209 | по запросу | ||
223-1-2-09 | по запросу |
Actuation type | Push-button |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 25.6 mm / 1.008 inch |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.412 MJ |
GTIN | 4045454810252 |
Height | 15 mm / 0.591 inch |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 9 |
Number of levels | 1 |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
Total number of connection points | 9 |
Total number of potentials | 9 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 18.552 г |
Ширина | 79.8 mm / 3.142 inch |
Серия: 2231 (100 из 343)
- 2231-121/008-000 2231-121/026-000 2231-121/031-000 2231-121/037-000 2231-121/102-000 2231-122/008-000 2231-122/026-000 2231-122/031-000 2231-122/037-000 2231-122/102-000 2231-123/008-000 2231-123/026-000 2231-123/031-000 2231-123/037-000 2231-123/102-000 2231-124/008-000 2231-124/026-000 2231-124/031-000 2231-124/037-000 2231-124/102-000 2231-202/008-000 2231-202/026-000 2231-202/031-000 2231-202/037-000 2231-203/008-000 2231-203/026-000 2231-203/031-000 2231-203/037-000 2231-204/008-000 2231-204/026-000 2231-204/031-000 2231-204/037-000 2231-205/008-000 2231-205/026-000 2231-205/031-000 2231-205/037-000 2231-206/008-000 2231-206/026-000 2231-206/031-000 2231-206/037-000 2231-207/008-000 2231-207/026-000 2231-207/031-000 2231-207/037-000 2231-208/008-000 2231-208/026-000 2231-208/031-000 2231-208/037-000 2231-209/008-000 2231-209/026-000 2231-209/031-000 2231-209/037-000 2231-210/008-000 2231-210/026-000 2231-210/031-000 2231-210/037-000 2231-211/008-000 2231-211/026-000 2231-211/031-000 2231-211/037-000 2231-212/008-000 2231-212/026-000 2231-212/031-000 2231-212/037-000 2231-213/008-000 2231-213/026-000 2231-213/031-000 2231-213/037-000 2231-216/008-000 2231-216/026-000 2231-216/031-000 2231-216/037-000 2231-302/008-000 2231-302/026-000 2231-302/031-000 2231-302/037-000 2231-302/102-000 2231-302/107-000 2231-303/008-000 2231-303/026-000 2231-303/031-000 2231-303/037-000 2231-303/102-000 2231-303/107-000 2231-304/008-000 2231-304/026-000 2231-304/031-000 2231-304/037-000 2231-304/102-000 2231-304/107-000 2231-305/008-000 2231-305/026-000 2231-305/031-000 2231-305/037-000 2231-305/102-000 2231-305/107-000 2231-306/008-000 2231-306/026-000 2231-306/031-000 2231-306/037-000
2231209/031000, 2231 209/031 000
