Datasheet Wago 2231-103/102-000 — Даташит
1-проводниковая розетка; Нажимная кнопка; со встроенной торцевой пластиной; 2,5 мм²; Шаг контактов 5 мм; 3-пол.
1-CONDUCTOR FEMALE PLUG; PUSH-BU | |||
2231-103/102-000 Wago | по запросу |
Actuation type | Push-button |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 25.6 mm / 1.008 inch |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.095 MJ |
GTIN | 4045454907631 |
Height | 15 mm / 0.591 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 3 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Plugging without loss of pin spacing | 1 |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Вес | 4.649 г |
Ширина | 15 mm / 0.591 inch |
Серия: 2231 (100 из 343)
- 2231-102/008-000 2231-102/026-000 2231-102/031-000 2231-102/037-000 2231-102/102-000 2231-103/008-000 2231-103/026-000 2231-103/026-000/133-000 2231-103/031-000 2231-103/037-000 2231-103/102-000 2231-104/008-000 2231-104/026-000 2231-104/031-000 2231-104/037-000 2231-104/102-000 2231-105/008-000 2231-105/026-000 2231-105/026-000/134-000 2231-105/031-000 2231-105/037-000 2231-105/037-000/134-000 2231-105/102-000 2231-106/008-000 2231-106/026-000 2231-106/031-000 2231-106/037-000 2231-106/102-000 2231-107/008-000 2231-107/026-000 2231-107/031-000 2231-107/037-000 2231-107/102-000 2231-108/008-000 2231-108/026-000 2231-108/031-000 2231-108/037-000 2231-108/102-000 2231-109/008-000 2231-109/026-000 2231-109/031-000 2231-109/037-000 2231-109/102-000 2231-110/008-000 2231-110/026-000 2231-110/031-000 2231-110/037-000 2231-110/102-000 2231-111/008-000 2231-111/026-000 2231-111/031-000 2231-111/037-000 2231-111/102-000 2231-112/008-000 2231-112/026-000 2231-112/031-000 2231-112/037-000 2231-112/102-000 2231-113/008-000 2231-113/026-000 2231-113/031-000 2231-113/037-000 2231-113/102-000 2231-114/008-000 2231-114/026-000 2231-114/031-000 2231-114/037-000 2231-114/102-000 2231-115/008-000 2231-115/026-000 2231-115/031-000 2231-115/037-000 2231-115/102-000 2231-116/008-000 2231-116/026-000 2231-116/031-000 2231-116/037-000 2231-116/102-000 2231-117/008-000 2231-117/026-000 2231-117/031-000 2231-117/037-000 2231-117/102-000 2231-118/008-000 2231-118/026-000 2231-118/031-000 2231-118/037-000 2231-118/102-000 2231-119/008-000 2231-119/026-000 2231-119/031-000 2231-119/037-000 2231-119/102-000 2231-120/008-000 2231-120/026-000 2231-120/031-000 2231-120/037-000 2231-120/102-000 2231-121/008-000 2231-121/026-000
2231103/102000, 2231 103/102 000
