Datasheet Wago 2092-1176/200-000 — Даташит
1-conductor THR female header; 1.4 mm Ø solder pin; прямые; 2,5 мм²; Шаг контактов 5 мм; 6-пол.
1-CONDUCTOR THR FEMALE HEADER; 1 | |||
2092-1176/200-000 Wago | по запросу |
Actuation type | Push-button |
Цвет | light gray |
Conductor entry angle to the PCB | 90 ° |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 13.4 mm / 0.528 inch |
Fine-stranded conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Fire load | 0.129 MJ |
GTIN | 4050821395416 |
Height | 16.2 mm / 0.638 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 6 |
Number of levels | 1 |
PCB contact | THR |
Pin spacing | 5 mm (0.197 inch) |
Plated through-hole diameter (THR) | 1.6 (+ 0.1) мм |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1.4 мм |
Solder pin length | 2.4 мм |
Solid conductor | 0.2 … 2.5 mm² / 24 … 12 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 6 |
Total number of potentials | 6 |
Вес | 6.55 г |
Ширина | 30 mm / 1.181 inch |
Серия: 2092 (100 из 338)
- 2092-1122 2092-1122/000-5000 2092-1123 2092-1123/000-5000 2092-1124 2092-1124/000-5000 2092-1125 2092-1125/000-5000 2092-1126 2092-1126/000-5000 2092-1127 2092-1128 2092-1128/000-5000 2092-1129 2092-1130 2092-1130/000-5000 2092-1132 2092-1132/000-5000 2092-1152 2092-1152/000-5000 2092-1153 2092-1153/000-5000 2092-1154 2092-1154/000-5000 2092-1155 2092-1155/000-5000 2092-1156 2092-1156/000-5000 2092-1157 2092-1158 2092-1158/000-5000 2092-1159 2092-1160 2092-1160/000-5000 2092-1162 2092-1162/000-5000 2092-1172 2092-1172/000-5000 2092-1172/200-000 2092-1173 2092-1173/000-5000 2092-1173/200-000 2092-1174 2092-1174/000-5000 2092-1174/200-000 2092-1175 2092-1175/000-5000 2092-1175/200-000 2092-1176 2092-1176/000-5000 2092-1176/200-000 2092-1177 2092-1178 2092-1178/000-5000 2092-1178/200-000 2092-1179 2092-1180 2092-1180/000-5000 2092-1180/200-000 2092-1182 2092-1182/000-5000 2092-1182/200-000 2092-1302 2092-1302/200-000 2092-1303 2092-1303/200-000 2092-1304 2092-1304/200-000 2092-1305 2092-1305/200-000 2092-1306 2092-1306/200-000 2092-1322 2092-1322/200-000 2092-1323 2092-1323/200-000 2092-1324 2092-1324/200-000 2092-1325 2092-1325/200-000 2092-1326 2092-1326/200-000 2092-1352 2092-1352/000-5000 2092-1353 2092-1353/000-5000 2092-1354 2092-1354/000-5000 2092-1355 2092-1355/000-5000 2092-1356 2092-1356/000-5000 2092-1357 2092-1358 2092-1358/000-5000 2092-1359 2092-1360 2092-1360/000-5000 2092-1362 2092-1362/000-5000
20921176/200000, 2092 1176/200 000
