Datasheet Wago 2091-1382 — Даташит
1-conductor THT female header; Вывод под пайку 1 мм Ø; угловые; 1,5; Шаг контактов 3,5 мм; 12-пол.
1-CONDUCTOR THT FEMALE HEADER1.0 MM SOLDER PIN ANGLED, LIGHT GRAY | |||
2091-1382/000-1000 Wago | по запросу | ||
Actuation type | Push-button |
Цвет | light gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 14 mm / 0.551 inch |
Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.142 MJ |
GTIN | 4050821162933 |
Height | 11.4 mm / 0.449 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mismating protection | No |
Number of Poles | 12 |
Number of levels | 1 |
PCB contact | THT |
Product Group | 26 (picoMAX) |
Rated current | 10 A |
Solder pin diameter | 1 мм |
Solder pin length | 3.6 мм |
Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 12 |
Total number of potentials | 12 |
Вес | 6.992 г |
Ширина | 42 mm / 1.654 inch |
Серия: 2091 (100 из 308)
- 2091-1353/000-1000 2091-1353/000-5000 2091-1354 2091-1354/000-1000 2091-1354/000-5000 2091-1355 2091-1355/000-1000 2091-1355/000-5000 2091-1356 2091-1356/000-1000 2091-1356/000-5000 2091-1357 2091-1358 2091-1358/000-1000 2091-1358/000-5000 2091-1360 2091-1360/000-1000 2091-1360/000-5000 2091-1362 2091-1362/000-1000 2091-1362/000-5000 2091-1372 2091-1372/000-1000 2091-1372/000-5000 2091-1372/200-000 2091-1373 2091-1373/000-1000 2091-1373/000-5000 2091-1373/200-000 2091-1374 2091-1374/000-1000 2091-1374/000-5000 2091-1374/200-000 2091-1375 2091-1375/000-1000 2091-1375/000-5000 2091-1375/200-000 2091-1376 2091-1376/000-1000 2091-1376/000-5000 2091-1376/200-000 2091-1377 2091-1378 2091-1378/000-1000 2091-1378/000-5000 2091-1378/200-000 2091-1380 2091-1380/000-1000 2091-1380/000-5000 2091-1380/200-000 2091-1382 2091-1382/000-1000 2091-1382/000-5000 2091-1382/200-000 2091-1402 2091-1402/005-000 2091-1402/200-000 2091-1402/205-000 2091-1403 2091-1403/005-000 2091-1403/200-000 2091-1403/205-000 2091-1404 2091-1404/005-000 2091-1404/200-000 2091-1404/205-000 2091-1405 2091-1405/005-000 2091-1405/200-000 2091-1405/205-000 2091-1406 2091-1406/005-000 2091-1406/200-000 2091-1406/205-000 2091-1407/200-000 2091-1408 2091-1408/005-000 2091-1408/200-000 2091-1408/205-000 2091-1410 2091-1410/005-000 2091-1410/200-000 2091-1410/205-000 2091-1412 2091-1412/200-000 2091-1412/205-000 2091-1422 2091-1422/005-000 2091-1422/200-000 2091-1422/200-000/997-405 2091-1422/205-000 2091-1423 2091-1423/005-000 2091-1423/200-000 2091-1423/200-000/997-406 2091-1423/205-000 2091-1424 2091-1424/005-000 2091-1424/200-000 2091-1424/200-000/997-406
20911382, 2091 1382
