Datasheet Wago 2091-1175/200-000 — Даташит
1-conductor THR female header; Вывод под пайку 1 мм Ø; прямые; 1,5; Шаг контактов 3,5 мм; 5-пол.
1-CONDUCTOR THR FEMALE HEADER1.0 MM SOLDER PIN STRAIGHT, LIGHT GRAY | |||
2091-1175/200-000/997-405 Wago | по запросу | ||
Actuation type | Push-button |
Цвет | light gray |
Conductor entry angle to the PCB | 90 ° |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 11.4 mm / 0.449 inch |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 0.75 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.053 MJ |
GTIN | 4050821395881 |
Height | 14 mm / 0.551 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 5 |
Number of levels | 1 |
PCB contact | THR |
Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
Rated current | 10 A |
Solder pin diameter | 1 мм |
Solder pin length | 2.4 мм |
Solid conductor | 0.2 … 1.5 mm² / 24 … 14 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 5 |
Total number of potentials | 5 |
Вес | 2.587 г |
Ширина | 17.5 mm / 0.689 inch |
Серия: 2091 (100 из 308)
- 2091-1122 2091-1123 2091-1124 2091-1125 2091-1126 2091-1128 2091-1130 2091-1132 2091-1152 2091-1152/000-5000 2091-1153 2091-1153/000-1000 2091-1153/000-5000 2091-1154 2091-1154/000-1000 2091-1154/000-5000 2091-1155 2091-1155/000-1000 2091-1155/000-5000 2091-1156 2091-1156/000-1000 2091-1156/000-5000 2091-1157 2091-1158 2091-1158/000-1000 2091-1158/000-5000 2091-1160 2091-1160/000-1000 2091-1160/000-5000 2091-1162 2091-1162/000-1000 2091-1162/000-5000 2091-1172 2091-1172/000-1000 2091-1172/000-5000 2091-1172/200-000 2091-1172/200-000/997-404 2091-1173 2091-1173/000-1000 2091-1173/000-5000 2091-1173/200-000 2091-1173/200-000/997-405 2091-1174 2091-1174/000-1000 2091-1174/000-5000 2091-1174/200-000 2091-1174/200-000/997-405 2091-1175 2091-1175/000-1000 2091-1175/000-5000 2091-1175/200-000 2091-1175/200-000/997-405 2091-1176 2091-1176/000-1000 2091-1176/000-5000 2091-1176/200-000 2091-1176/200-000/997-407 2091-1177/200-000/997-407 2091-1178 2091-1178/000-1000 2091-1178/000-5000 2091-1178/200-000 2091-1178/200-000/997-407 2091-1180 2091-1180/000-1000 2091-1180/000-5000 2091-1180/200-000 2091-1180/200-000/997-407 2091-1182 2091-1182/000-1000 2091-1182/000-5000 2091-1182/200-000 2091-1182/200-000/997-407 2091-1302 2091-1302/200-000 2091-1304 2091-1304/200-000 2091-1306 2091-1306/200-000 2091-1308 2091-1308/200-000 2091-1322 2091-1322/200-000 2091-1324 2091-1324/200-000 2091-1326 2091-1326/200-000 2091-1328 2091-1328/200-000 2091-1352 2091-1352/000-1000 2091-1352/000-5000 2091-1353 2091-1353/000-1000 2091-1353/000-5000 2091-1354 2091-1354/000-1000 2091-1354/000-5000 2091-1355 2091-1355/000-1000
20911175/200000, 2091 1175/200 000
