Datasheet Wago 890-802 — Даташит
Розетка для печатных плат; прямые; 2-пол.; Код. A
![]() 12 предложений от 4 поставщиков SOCKET FOR PCBS STRAIGHT 2-POLE; | |||
890-802/011-000 | от 285 ₽ | ||
890-802/011-000 Wago | от 292 ₽ | ||
890-802/011-000 Wago | 405 ₽ | ||
890-802 Wago | по запросу |
Coding | A |
Цвет | black |
Connector connection type | for PCBs |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 12.2 mm / 0.48 inch |
Design | straight |
Drilled hole diameter (tolerance) | 1.3(+ 0.1 ... - 0.1) мм |
Fire load | 0.048 MJ |
GTIN | 4045454544829 |
Height | 31.9 mm / 1.256 inch |
Height from the surface | 28.4 mm / 1.118 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | L N |
Mating direction to the PCB | 90 ° |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Mismating protection | Yes |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 4.4 mm (0.173 inch) |
Potential marking | L N |
Product Group | 20 (WINSTA) |
Rated current | 16 A |
Rated voltage (III / 3) | 250 В |
Retention force of a plug-in connection | when locked: > 80N |
Solder pin arrangement | 2 in-line solder pins/pole |
Solder pin dimensions | 1 x 0.8 mm |
Solder pin length | 3.5 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of potentials | 2 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 2.54 г |
Ширина | 10.4 mm / 0.41 inch |
Серия: 890 (100 из 384)
- 890-752/060-000 890-753 890-753/060-000 890-753/062-000 890-754 890-754/060-000 890-754/062-000 890-754/064-000 890-755 890-755/060-000 890-755/062-000 890-762 890-763 890-763/071-000 890-763/073-000 890-764 890-764/071-000 890-764/072-000 890-764/073-000 890-765 890-765/073-000 890-772 890-773 890-773/071-000 890-773/073-000 890-774 890-774/071-000 890-774/072-000 890-774/073-000 890-775/073-000 890-782 890-782/080-000 890-782/082-000 890-783 890-783/081-000 890-783/082-000 890-784 890-784/081-000 890-785/080-000 890-785/082-000 890-792 890-792/080-000 890-792/082-000 890-793 890-793/081-000 890-793/082-000 890-794 890-794/081-000 890-795/080-000 890-795/082-000 890-802 890-802/011-000 890-812 890-813/011-000 890-814 890-814/011-000 890-815 890-815/011-000 890-822 890-822/011-000 890-823 890-823/011-000 890-824 890-824/011-000 890-825 890-825/011-000 890-832 890-832/011-000 890-833 890-833/011-000 890-834 890-834/011-000 890-835 890-835/011-000 890-842 890-842/011-000 890-843 890-843/011-000 890-844 890-844/011-000 890-845 890-845/011-000 890-852 890-852/011-000 890-853 890-853/011-000 890-854 890-854/011-000 890-855 890-855/011-000 890-862 890-862/011-000 890-863 890-863/011-000 890-864 890-864/011-000 890-865 890-865/011-000 890-872 890-872/011-000
