Datasheet Wago 831-3108/037-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Фиксирующий рычаг; 10 мм²; Шаг контактов 7,62 мм; 8-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
831-3108/037-000 Wago | по запросу |
Цвет | light gray |
Connection technology 2 | Quick-connect/Solder contact |
Country of origin | DE |
Габариты: глубина | 41.9 mm / 1.65 inch |
Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.5 … 6 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.5 … 6 mm² |
Fire load | 0.941 MJ |
GTIN | 4045454334123 |
Height | 27.5 mm / 1.083 inch |
Locking of plug-in connection | locking lever |
Material group | I |
Material of the additional spring for socket contact | Chrome nickel spring steel (CrNi) |
Mismating protection | Yes |
Number of Poles | 8 |
Number of levels | 1 |
Pin spacing | 7.62 mm (0.3 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 800 В |
Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
Total number of connection points | 8 |
Total number of potentials | 8 |
Вес | 62.45 г |
Ширина | 87.64 mm / 3.45 inch |
Серия: 831 (100 из 103)
- 831-137 831-3102 831-3102/000-9037 831-3102/037-000 831-3102/037-9037 831-3102/133-000 831-3103 831-3103/000-9037 831-3103/037-000 831-3103/037-9037 831-3103/133-000 831-3104 831-3104/000-9037 831-3104/037-000 831-3104/037-9037 831-3104/135-000 831-3105 831-3105/000-9035 831-3105/000-9037 831-3105/037-000 831-3105/037-9037 831-3105/1019-004 831-3105/1019-050 831-3105/135-000 831-3106 831-3106/000-9037 831-3106/037-000 831-3106/037-9037 831-3106/135-000 831-3107 831-3107/000-9037 831-3107/037-000 831-3107/037-9037 831-3107/136-000 831-3108 831-3108/000-9037 831-3108/037-000 831-3108/037-9037 831-3108/136-000 831-3109 831-3109/037-000 831-3109/136-000 831-3202 831-3202/000-9034 831-3202/007-000 831-3202/007-9034 831-3202/133-000 831-3203 831-3203/000-9034 831-3203/007-000 831-3203/007-9034 831-3203/133-000 831-3204 831-3204/000-9034 831-3204/007-000 831-3204/007-9034 831-3204/135-000 831-3205 831-3205/000-9032 831-3205/000-9034 831-3205/007-000 831-3205/007-9034 831-3205/1020-004 831-3205/1020-050 831-3205/135-000 831-3206 831-3206/000-9034 831-3206/007-000 831-3206/007-9034 831-3206/135-000 831-3207 831-3207/000-9034 831-3207/007-000 831-3207/007-9034 831-3207/136-000 831-3208 831-3208/000-9034 831-3208/007-000 831-3208/007-9034 831-3208/136-000 831-3209 831-3209/007-000 831-3209/136-000 831-3602 831-3603 831-3604 831-3605 831-3606 831-3607 831-3608 831-3609 831-3622 831-3623 831-3624 831-3625 831-3626 831-3627 831-3628 831-3629 831-500
8313108/037000, 831 3108/037 000
