Datasheet Wago 806-202 — Даташит
2-проводные клеммы для печатных плат; 1,5; Шаг контактов 5 мм; 2-пол.; Push-in CAGE CLAMP
2-CONDUCTOR PCB TERMINAL BLOCK; | |||
806-202 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 19.8 mm / 0.78 inch |
Fine-stranded conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
Fire load | 0.059 MJ |
GTIN | 4045454077068 |
Height | 23.3 mm / 0.917 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Number of Poles | 2 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 10 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin diameter | 1 мм |
Solid conductor | 0.2 … 1.5 mm² / 24 … 16 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 4 |
Total number of potentials | 2 |
Вес | 2.826 г |
Ширина | 11.5 mm / 0.453 inch |
Серия: 806 (33)
