Datasheet Wago 804-104/000-004 — Даташит
Клеммная колодка для печатной платы; Кнопка; 2,5 мм²; Шаг контактов 5 мм; 4-полюсный; Зажим Push-in CAGE CLAMP
804-104/000-006 Wago | 551 ₽ | ||
804-104/000-006 Wago | по запросу |
Actuation type | Push-button |
Цвет | black |
Country of origin | CH |
Габариты: глубина | 15 mm / 0.591 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 12 AWG |
GTIN | 4055143248174 |
Height | 18.1 mm / 0.713 inch |
Height from the surface | 14.5 mm / 0.571 inch |
Material group | I |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THT |
Packaging type | BOX |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.8 x 0.6 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.25 … 2.5 mm² / 20 … 12 AWG |
Strip length | 10 … 11 mm / 0.39 … 0.43 Inch |
Total number of connection points | 4 |
Total number of potentials | 4 |
Вес | 5.114 г |
Ширина | 21.5 mm / 0.846 inch |
Серия: 804 (30)
- PCB Interconnect
804104/000004, 804 104/000 004
