Datasheet Wago 770-844/060-000 — Даташит
Разъем; - для печатных плат; 4-пол.; Шаг контактов 10 мм / 0,394 дюйма; 100% защита от неправильного подсоединения
SOCKET FOR PCBS STRAIGHT 4-POLE, | |||
770-844/060-000 Wago | по запросу |
Coding | B |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper or copper alloy, surface-treated |
Country of origin | DE |
Degree of protection | IP20 |
Габариты: глубина | 14.6 mm / 0.575 inch |
Design | straight |
Drilled hole diameter (tolerance) | 1.5(+ 0.1 ... - 0.1) мм |
Fire load | 0.157 MJ |
GTIN | 4050821555469 |
Height | 29.5 mm / 1.161 inch |
Height from the surface | 26 mm / 1.024 inch |
Locking lever | да |
Locking of plug-in connection | locking lever |
Marking | N ⏚ 2|L 1|L' |
Mating direction to the PCB | 90 ° |
Mating force of a plug-in connection | approx. 20 … 70 N (depending on pole number) |
Number of Poles | 4 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Potential marking | N ⏚ 2/L 1/L' |
Rated current | 25 A |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 3) | 400 В |
Retention force of a plug-in connection | when locked: > 80N |
Solder pin arrangement | 2 in-line solder pins/pole |
Solder pin dimensions | 1 x 0.8 mm |
Solder pin length | 3.5 мм |
Surrounding air (operating) temperature | -35 … 85 °C |
Total number of potentials | 4 |
Unmating force of a plug-in connection | when unlocked: approx. 20 … 70 N (depending on pole number) |
Вес | 8.478 г |
Ширина | 37 mm / 1.457 inch |
Серия: 770 (100 из 608)
- 770-783/081-000 770-783/082-000 770-784 770-784/081-000 770-785 770-785/080-000 770-785/082-000 770-793 770-793/081-000 770-793/082-000 770-794 770-794/081-000 770-795 770-795/080-000 770-795/082-000 770-803 770-803/011-000 770-804 770-804/011-000 770-805 770-805/011-000 770-813 770-813/011-000 770-814 770-814/011-000 770-815 770-815/011-000 770-823 770-823/011-000 770-824 770-824/011-000 770-825 770-825/011-000 770-833 770-833/011-000 770-834 770-834/011-000 770-835 770-835/011-000 770-843 770-843/011-000 770-843/011-000/060-000 770-843/011-000/062-000 770-843/060-000 770-843/062-000 770-844 770-844/011-000 770-844/011-000/060-000 770-844/011-000/062-000 770-844/011-000/064-000 770-844/060-000 770-844/062-000 770-844/064-000 770-845 770-845/011-000 770-845/011-000/060-000 770-845/011-000/062-000 770-845/011-000/064-000 770-845/060-000 770-845/062-000 770-845/064-000 770-853 770-853/011-000 770-853/011-000/060-000 770-853/011-000/062-000 770-853/060-000 770-853/062-000 770-854 770-854/011-000 770-854/011-000/060-000 770-854/011-000/062-000 770-854/011-000/064-000 770-854/060-000 770-854/062-000 770-854/064-000 770-855 770-855/011-000 770-855/011-000/060-000 770-855/011-000/062-000 770-855/011-000/064-000 770-855/060-000 770-855/062-000 770-855/064-000 770-863 770-863/011-000 770-863/011-000/071-000 770-863/011-000/073-000 770-863/071-000 770-863/073-000 770-864 770-864/011-000 770-864/011-000/071-000 770-864/011-000/072-000 770-864/011-000/073-000 770-864/071-000 770-864/072-000 770-864/073-000 770-865 770-865/011-000 770-865/073-000
770844/060000, 770 844/060 000
