Datasheet Wago 769-645/003-000 — Даташит
Вилка THT; 1.0 x 1.0 mm solder pin; прямые; зажимное кольцо; Шаг контактов 5 мм; 15-пол.
THT MALE HEADER; 1.0 X 1.0 MM SO | |||
769-645/004-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | PL |
Габариты: глубина | 22.2 mm / 0.874 inch |
Fire load | 0.339 MJ |
GTIN | 4017332412995 |
Height from the surface | 22.2 mm / 0.874 inch |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 15 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm / 0.197 inch |
Product Group | 18 (X-COM-System) |
Rated current | 32 A |
Rated voltage (III / 2) | 500 В |
Rated voltage (III / 3) | 250 В |
Solder pin dimensions | Solder pin 1 x 1 mm |
Total number of potentials | 15 |
Вес | 15.75 г |
Ширина | 89.7 mm / 3.531 inch |
Серия: 769 (100 из 460)
- 769-633/000-036 769-633/003-000 769-633/003-036 769-633/004-000 769-633/007-000 769-634 769-634/000-036 769-634/003-000 769-634/003-036 769-634/004-000 769-634/007-000 769-635 769-635/000-036 769-635/003-000 769-635/003-036 769-635/004-000 769-635/007-000 769-636 769-636/003-000 769-636/003-036 769-636/004-000 769-636/007-000 769-637 769-637/003-000 769-637/004-000 769-637/007-000 769-638 769-638/003-000 769-638/004-000 769-638/007-000 769-639 769-639/003-000 769-639/004-000 769-639/007-000 769-640 769-640/003-000 769-640/004-000 769-640/007-000 769-641 769-641/003-000 769-641/004-000 769-641/007-000 769-642 769-642/003-000 769-642/004-000 769-642/007-000 769-643 769-643/003-000 769-643/004-000 769-643/007-000 769-644 769-644/003-000 769-644/004-000 769-644/007-000 769-645 769-645/003-000 769-645/004-000 769-645/007-000 769-662 769-662/003-000 769-662/004-000 769-663 769-663/003-000 769-663/004-000 769-664 769-664/003-000 769-664/004-000 769-665 769-665/003-000 769-665/004-000 769-666 769-666/003-000 769-666/004-000 769-667 769-667/003-000 769-667/004-000 769-668 769-668/003-000 769-668/004-000 769-669 769-669/003-000 769-669/004-000 769-670 769-670/003-000 769-670/004-000 769-671 769-671/003-000 769-671/004-000 769-672 769-672/003-000 769-672/004-000 769-673 769-673/003-000 769-673/004-000 769-674 769-674/003-000 769-674/004-000 769-675 769-675/003-000 769-675/004-000
769645/003000, 769 645/003 000
