Datasheet Wago 745-1405 — Даташит
Серия745
Модель745-1405
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 12,5 мм; 5-полюсный; CAGE CLAMP
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB45 °
Contact platingtin-plated
Country of originPL
Габариты: глубина29.1 mm / 1.146 inch
Drilled hole diameter (tolerance)1.8(+ 0.1) мм
Fine-stranded conductor0.2 … 6 mm² / 24 … 10 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 4 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 4 mm²
Fire load0.602 MJ
GTIN4045454623760
Height27.5 mm / 1.083 inch
Height from the surface23 mm / 0.906 inch
Material groupI
Number of Poles5
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing12.5 mm (0.492 inch)
Rated current41 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)1000 В
Solder pin dimensions1 x 1.4 mm
Solder pin length4.5 мм
Solid conductor0.2 … 6 mm² / 24 … 10 AWG
Strip length11 … 12 mm / 0.43 … 0.47 Inch
Total number of connection points5
Total number of potentials5
Вес31.652 г
Ширина59.1 mm / 2.327 inch
  • PCB Interconnect
7451405, 745 1405
На английском языке: Datasheet Wago 745-1405
