Datasheet Wago 745-360 — Даташит
Клеммная колодка для печатной платы; 6 мм²; Шаг контактов 10 мм; 10-полюсный; CAGE CLAMP; возможность объединения
PCB TERMINAL BLOCK; 6 MM; PIN SP | |||
745-360 Wago | по запросу |
Цвет | gray |
Country of origin | PL |
Габариты: глубина | 29.1 mm / 1.146 inch |
Drilled hole diameter (tolerance) | 1.8(+ 0.1) мм |
Fine-stranded conductor | 0.2 … 6 mm² / 24 … 10 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 4 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 4 mm² |
Fire load | 0.976 MJ |
GTIN | 4044918302555 |
Height | 27.5 mm / 1.083 inch |
Height from the surface | 23 mm / 0.906 inch |
Material group | I |
Number of Poles | 10 |
Number of jumper slots | 1 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10 mm (0.394 inch) |
Rated current | 41 A |
Rated impulse voltage (II / 2) | 8 kV |
Rated impulse voltage (III / 2) | 8 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 1000 В |
Rated voltage (III / 3) | 630 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 1 x 1.4 mm |
Solder pin length | 4.5 мм |
Solid conductor | 0.2 … 6 mm² / 24 … 10 AWG |
Strip length | 11 … 12 mm / 0.43 … 0.47 Inch |
Total number of connection points | 10 |
Total number of potentials | 10 |
Вес | 54.165 г |
Ширина | 99.1 mm / 3.902 inch |
Серия: 745 (100 из 266)
- 745-3111 745-3112 745-312 745-3138 745-3152 745-3153 745-3154 745-3155 745-3156 745-3157 745-3158 745-3159 745-3160 745-3161 745-3162 745-3202 745-3203 745-3204 745-3205 745-3206 745-3207 745-3208 745-3209 745-3210 745-3211 745-3212 745-3252 745-3253 745-3254 745-3255 745-3256 745-3257 745-3258 745-3259 745-3260 745-3261 745-3262 745-338 745-340 745-345 745-352 745-352/005-000 745-353 745-354 745-354/005-000 745-355 745-356 745-357 745-358 745-359 745-360 745-362 745-380 745-3801 745-3803 745-3803/999-950 745-3804 745-3807 745-3808 745-381 745-382 745-383 745-384 745-385 745-390 745-391 745-392 745-393 745-394 745-395 745-500 745-501/011-000 745-502/006-000 745-502/011-000 745-503/006-000 745-504/006-000 745-504/011-000 745-505/006-000 745-540 745-545 745-582 745-583 745-584 745-585 745-602/006-000 745-603/006-000 745-604/006-000 745-604/011-000 745-605/006-000 745-605/007-000 745-606/006-000 745-607/007-000 745-631 745-632 745-633 745-634 745-635 745-652/006-000 745-652/007-000 745-652/011-000
- PCB Interconnect
