Datasheet Wago 741-913 — Даташит
Стекируемый клеммный блок для печатных плат; Кнопка; 2,5 мм²; Шаг контактов 10,16 мм; 1-полюсный; CAGE CLAMP
STACKABLE PCB TERMINAL BLOCK PUS | |||
741-913 Wago | по запросу |
Actuation type | Push-button |
Цвет | orange |
Country of origin | CH |
Габариты: глубина | 12.8 mm / 0.504 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.043 MJ |
GTIN | 4044918678056 |
Height | 22.5 mm / 0.886 inch |
Height from the surface | 18.5 mm / 0.728 inch |
Material group | I |
Number of Poles | 1 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 10.16 mm (0.4 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 2) | 500 В |
Rated voltage (III / 3) | 630 В |
Solder pin arrangement | within the terminal block, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 1 |
Total number of potentials | 1 |
Вес | 1.98 г |
Ширина | 10.16 mm / 0.4 inch |
Серия: 741 (100 из 120)
- 741-140 741-142 741-146 741-202 741-203 741-204 741-205 741-206 741-207 741-208 741-209 741-210 741-212 741-216 741-232 741-233 741-234 741-235 741-236 741-237 741-238 741-239 741-240 741-242 741-246 741-302 741-303 741-304 741-305 741-306 741-307 741-308 741-309 741-310 741-322 741-323 741-324 741-325 741-326 741-327 741-328 741-329 741-330 741-402 741-403 741-404 741-405 741-406 741-407 741-408 741-409 741-410 741-422 741-423 741-424 741-425 741-426 741-427 741-428 741-429 741-430 741-502 741-503 741-504 741-505 741-506 741-507 741-508 741-522 741-523 741-524 741-525 741-526 741-527 741-528 741-600 741-602 741-603 741-604 741-605 741-606 741-607 741-608 741-622 741-623 741-624 741-625 741-626 741-627 741-628 741-901 741-902 741-903 741-904 741-905 741-906 741-911 741-912 741-913 741-916
- PCB Interconnect
