Datasheet Wago 737-404 — Даташит
Трехуровневая клеммная колодка для печатной платы; 2,5 мм²; Шаг контактов 5,08 мм; 3 x 4-полюсный; CAGE CLAMP
![]() 25 предложений от 11 поставщиков Модули Входа Питания , AMPHENOL INDUSTRIAL 10-737404-178 Power Entry Connector, RADSERT Series, Plug, 120A, Panel Mount, Screw | |||
10-737404-178 Amphenol | 249 ₽ | ||
10-737404-178 Amphenol | 292 ₽ | ||
10-737404-178 | от 542 ₽ | ||
10-737404-178 | по запросу |
Цвет | orange |
Country of origin | PL |
Габариты: глубина | 31 mm / 1.22 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.257 MJ |
GTIN | 4045454022976 |
Height | 44 mm / 1.732 inch |
Height from the surface | 40 mm / 1.575 inch |
Material group | I |
Number of Poles | 4 |
Number of levels | 3 |
PCB contact | THT |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 21 A |
Rated current (2) | 21 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated impulse voltage (II / 2) 2 | 4 kV |
Rated impulse voltage (III / 2) 2 | 4 kV |
Rated impulse voltage (III / 3) 2 | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (II / 2) 2 | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 2) 2 | 320 В |
Rated voltage (III / 3) | 250 В |
Rated voltage (III / 3) 2 | 320 В |
Ratings according to 2 | IEC/EN 60664-1 |
Ratings note | Between the modules |
Ratings note 2 | Between the decks |
Solder pin arrangement | within the terminal block, staggered |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 4 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Total number of connection points | 12 |
Total number of potentials | 12 |
Вес | 17.212 г |
Ширина | 21.32 mm / 0.839 inch |
Серия: 737 (85)
- 737-102 737-103 737-104 737-106 737-108 737-112 737-116 737-124 737-202 737-203 737-204 737-206 737-208 737-212 737-216 737-224 737-302 737-303 737-304 737-306 737-308 737-312 737-316 737-324 737-402 737-403 737-404 737-406 737-408 737-412 737-416 737-424 737-502 737-503 737-504 737-505 737-506 737-508 737-512 737-516 737-552 737-553 737-554 737-556 737-558 737-562 737-566 737-602 737-603 737-604 737-606 737-608 737-612 737-616 737-652 737-653 737-654 737-656 737-658 737-662 737-666 737-702 737-703 737-704 737-706 737-708 737-712 737-752 737-753 737-754 737-756 737-758 737-762 737-802 737-803 737-804 737-806 737-808 737-812 737-852 737-853 737-854 737-856 737-858 737-862
- PCB Interconnect
