Datasheet Wago 734-103/008-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Монтажные ножки; 1,5; Шаг контактов 3,5 мм; 3-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
734-103/008-000 Wago | по запросу |
Цвет | light gray |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 18.6 mm / 0.732 inch |
Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Fire load | 0.043 MJ |
GTIN | 4045454930660 |
Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
Height | 18.9 mm / 0.744 inch |
Height from the surface | 13.4 mm / 0.528 inch |
Material group | I |
Mismating protection | Yes |
Mounting type | Snap-in mounting foot |
Number of Poles | 3 |
Number of levels | 1 |
Rated current | 10 A |
Solid conductor | 0.08 … 1.5 mm² / 28 … 14 AWG |
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
Total number of connection points | 3 |
Total number of potentials | 3 |
Type of mounting | Panel mounting |
Вес | 2.35 г |
Ширина | 12.7 mm / 0.5 inch |
Серия: 734 (100 из 708)
- 734-102 734-102/008-000 734-102/037-000 734-102/037-000/032-000 734-102/107-000 734-103 734-103/008-000 734-103/037-000 734-103/037-000/032-000 734-103/107-000 734-104 734-104/008-000 734-104/037-000 734-104/037-000/033-000 734-104/107-000 734-105 734-105/008-000 734-105/037-000 734-105/037-000/033-000 734-105/107-000 734-106 734-106/008-000 734-106/037-000 734-106/037-000/033-000 734-106/107-000 734-107 734-107/008-000 734-107/033-000 734-107/037-000 734-107/037-000/033-000 734-107/107-000 734-108 734-108/008-000 734-108/037-000 734-108/037-000/033-000 734-108/107-000 734-109 734-109/008-000 734-109/037-000 734-109/037-000/034-000 734-109/107-000 734-110 734-110/000-005 734-110/000-006 734-110/008-000 734-110/037-000 734-110/107-000 734-111 734-111/008-000 734-111/037-000 734-111/037-000/034-000 734-111/107-000 734-112 734-112/008-000 734-112/037-000 734-112/107-000 734-113 734-113/008-000 734-113/037-000 734-113/037-000/035-000 734-113/107-000 734-114 734-114/008-000 734-114/037-000 734-114/037-000/035-000 734-114/107-000 734-116 734-116/008-000 734-116/037-000 734-116/037-000/035-000 734-116/107-000 734-118 734-118/008-000 734-118/037-000 734-118/037-000/036-000 734-118/107-000 734-120 734-120/008-000 734-120/037-000 734-120/037-000/036-000 734-120/107-000 734-124 734-124/008-000 734-124/037-000 734-124/037-000/036-000 734-124/107-000 734-126 734-127 734-128 734-129 734-130 734-132 734-132/046-000 734-132/105-604 734-132/105-604/997-405 734-132/108-000 734-133 734-133/010-000 734-133/046-000 734-133/105-604
734103/008000, 734 103/008 000
