Datasheet Wago 722-839/031-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; 100% защита от неправильного подсоединения; зажимное кольцо; Шаг контактов 7,5 мм; 9-пол.
THT FEMALE HEADER; 0.6 X 1.0 MM | |||
722-839 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 18.25 mm / 0.719 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
GTIN | 4055143759366 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 11.6 mm / 0.457 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | Yes |
Mounting type | Mounting flange |
Number of Poles | 9 |
Number of levels | 1 |
PCB contact | THT |
Packaging type | BOX |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 9 |
Type of mounting | Feed-through mounting Panel mounting |
Вес | 10.532 г |
Ширина | 79.8 mm / 3.142 inch |
Серия: 722 (100 из 306)
- 722-246 722-246/005-000 722-246/005-000/039-000 722-246/031-000 722-246/039-000 722-246/047-000 722-250 722-250/005-000 722-250/005-000/039-000 722-250/031-000 722-250/039-000 722-250/047-000 722-732 722-732/031-000 722-732/039-000 722-732/047-000 722-733 722-733/031-000 722-733/039-000 722-733/047-000 722-734 722-734/031-000 722-734/039-000 722-734/047-000 722-735 722-735/031-000 722-735/039-000 722-735/047-000 722-736 722-736/031-000 722-736/039-000 722-736/047-000 722-737 722-737/031-000 722-737/039-000 722-737/047-000 722-738 722-738/031-000 722-738/039-000 722-738/047-000 722-739 722-739/031-000 722-739/039-000 722-739/047-000 722-740 722-740/031-000 722-740/039-000 722-740/047-000 722-741 722-741/031-000 722-741/039-000 722-741/047-000 722-742 722-742/031-000 722-742/039-000 722-742/047-000 722-832 722-832/031-000 722-832/039-000 722-832/047-000 722-833 722-833/031-000 722-833/039-000 722-833/047-000 722-834 722-834/031-000 722-834/039-000 722-834/047-000 722-835 722-835/031-000 722-835/039-000 722-835/047-000 722-836 722-836/031-000 722-836/039-000 722-836/047-000 722-837 722-837/031-000 722-837/039-000 722-837/047-000 722-838 722-838/031-000 722-838/039-000 722-838/047-000 722-839 722-839/031-000 722-839/039-000 722-839/047-000 722-840 722-840/031-000 722-840/039-000 722-840/047-000 722-841 722-841/031-000 722-841/039-000 722-841/047-000 722-842 722-842/031-000 722-842/039-000 722-842/047-000
722839/031000, 722 839/031 000
