Datasheet Wago 722-137/039-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; 100% защита от неправильного подсоединения; Фиксирующий рычаг; Шаг контактов 5 мм; 7-пол.
FEMALE CONNECTOR FOR RAIL-MOUNT | |||
722-137/005-000 Wago | по запросу |
Цвет | light gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 11.6 mm / 0.457 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fire load | 0.134 MJ |
GTIN | 4050821612223 |
Height | 26.6 mm / 1.047 inch |
Height from the surface | 21.6 mm / 0.85 inch |
Limit temperature range | -60 … +85 °C |
Locking of plug-in connection | locking lever |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | Yes |
Number of Poles | 7 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 7 |
Вес | 7.4 г |
Ширина | 50.8 mm / 2 inch |
Серия: 722 (100 из 306)
- 722-102/026-000 722-103/026-000 722-104/026-000 722-105/026-000 722-106/026-000 722-107/026-000 722-108/026-000 722-109/026-000 722-110/026-000 722-111/026-000 722-112/026-000 722-114/026-000 722-116/026-000 722-120/026-000 722-132 722-132/005-000 722-132/005-000/039-000 722-132/031-000 722-132/039-000 722-132/047-000 722-133 722-133/005-000 722-133/005-000/039-000 722-133/031-000 722-133/039-000 722-133/047-000 722-134 722-134/005-000 722-134/005-000/039-000 722-134/031-000 722-134/039-000 722-134/047-000 722-135 722-135/005-000 722-135/005-000/039-000 722-135/031-000 722-135/039-000 722-135/047-000 722-136 722-136/005-000 722-136/005-000/039-000 722-136/031-000 722-136/039-000 722-136/047-000 722-137 722-137/005-000 722-137/005-000/039-000 722-137/031-000 722-137/039-000 722-137/047-000 722-138 722-138/005-000 722-138/005-000/039-000 722-138/031-000 722-138/039-000 722-138/047-000 722-139 722-139/005-000 722-139/005-000/039-000 722-139/031-000 722-139/039-000 722-139/047-000 722-140 722-140/005-000 722-140/005-000/039-000 722-140/031-000 722-140/039-000 722-140/047-000 722-141 722-141/005-000 722-141/005-000/039-000 722-141/031-000 722-141/039-000 722-141/047-000 722-142 722-142/005-000 722-142/005-000/039-000 722-142/031-000 722-142/039-000 722-142/047-000 722-143 722-143/005-000 722-143/031-000 722-143/039-000 722-143/047-000 722-144 722-144/005-000 722-144/005-000/039-000 722-144/031-000 722-144/039-000 722-144/047-000 722-145 722-145/005-000 722-145/031-000 722-145/039-000 722-145/047-000 722-146 722-146/005-000 722-146/005-000/039-000 722-146/031-000
722137/039000, 722 137/039 000
