Datasheet Wago 714-168 — Даташит
Вилка THT; 0.8 x 0.8 mm solder pin; угловые; Шаг контактов 3,5 мм; 8-пол.
THT MALE HEADER; 0.8 X 0.8 MM SO | |||
714-168 Wago | по запросу |
Цвет | black |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 9.7 mm / 0.382 inch |
Drilled hole diameter (tolerance) | 1.2(+ 0.1) мм |
Fire load | 0.035 MJ |
GTIN | 4045454859701 |
Height | 10.3 mm / 0.406 inch |
Height from the surface | 6.9 mm / 0.272 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mismating protection | No |
Number of Poles | 8 |
Number of levels | 1 |
PCB contact | THT |
Rated current | 8 A |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 0.8 x 0.8 mm |
Solder pin length | 3.4 мм |
Total number of potentials | 8 |
Вес | 1.71 г |
Ширина | 29.4 mm / 1.157 inch |
Серия: 714 (43)
- 714-101 714-102 714-102/000-047 714-103 714-103/000-047 714-104 714-104/000-047 714-105 714-105/000-047 714-106 714-106/000-047 714-108 714-108/000-047 714-110 714-110/000-047 714-112 714-112/000-047 714-114 714-114/000-047 714-115 714-116 714-132 714-133 714-134 714-135 714-136 714-138 714-140 714-142 714-144 714-145 714-146 714-162 714-163 714-164 714-165 714-166 714-168 714-170 714-172 714-174 714-175 714-176
