Datasheet Wago 713-1410/117-000 — Даташит
Вилка под пайку THR, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; Резьбовой фланец; Шаг контактов 3,5 мм; 2 x 10-полюсов
THR MALE HEADER, 2-ROW; 0.8 X 0. | |||
713-1410/117-000/997-408 Wago | по запросу |
Цвет | black |
Connector connection type | for PCBs |
Country of origin | PL |
Габариты: глубина | 13.3 mm / 0.524 inch |
Fire load | 0.115 MJ |
GTIN | 4050821156475 |
Height | 15.9 mm / 0.626 inch |
Height from the surface | 13.5 mm / 0.531 inch |
Insulating material | Polyphtalamide (PPA GF) |
Locking of plug-in connection | Threaded flange |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | Yes |
Number of Poles | 20 |
Number of levels | 2 |
PCB contact | THR |
Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
Rated current | 10 A |
Rated voltage (II / 2) | 250 В |
Rated voltage (III / 3) | 80 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 0.8 x 0.8 mm |
Solder pin length | 2.4 мм |
Total number of potentials | 20 |
Вес | 5.7 г |
Ширина | 45.1 mm / 1.776 inch |
Серия: 713 (100 из 548)
- 713-1405/037-000 713-1405/105-000 713-1405/107-000 713-1405/116-000 713-1405/116-000/997-406 713-1405/117-000 713-1405/117-000/997-406 713-1406 713-1406/037-000 713-1406/105-000 713-1406/105-000/997-406 713-1406/107-000 713-1406/116-000 713-1406/116-000/997-406 713-1406/117-000 713-1406/117-000/997-406 713-1407 713-1407/037-000 713-1407/105-000 713-1407/105-000/997-406 713-1407/107-000 713-1407/116-000 713-1407/116-000/997-407 713-1407/117-000 713-1407/117-000/997-407 713-1408 713-1408/037-000 713-1408/105-000 713-1408/105-000/997-406 713-1408/107-000 713-1408/116-000 713-1408/116-000/997-407 713-1408/117-000 713-1408/117-000/997-407 713-1409 713-1409/037-000 713-1409/105-000 713-1409/105-000/997-407 713-1409/107-000 713-1409/116-000 713-1409/116-000/997-407 713-1409/117-000 713-1409/117-000/997-407 713-1410 713-1410/037-000 713-1410/105-000 713-1410/105-000/997-407 713-1410/107-000 713-1410/116-000 713-1410/116-000/997-408 713-1410/117-000 713-1410/117-000/997-408 713-1411 713-1411/037-000 713-1411/105-000 713-1411/105-000/997-407 713-1411/107-000 713-1411/116-000 713-1411/116-000/997-408 713-1411/117-000 713-1411/117-000/997-408 713-1412 713-1412/037-000 713-1412/105-000 713-1412/105-000/997-408 713-1412/107-000 713-1412/116-000 713-1412/116-000/997-408 713-1412/117-000 713-1412/117-000/997-408 713-1413 713-1413/037-000 713-1413/105-000 713-1413/105-000/997-408 713-1413/107-000 713-1413/116-000 713-1413/116-000/997-408 713-1413/117-000 713-1413/117-000/997-408 713-1414 713-1414/037-000 713-1414/105-000 713-1414/105-000/997-408 713-1414/107-000 713-1414/116-000 713-1414/116-000/997-408 713-1414/117-000 713-1414/117-000/997-408 713-1415 713-1415/037-000 713-1415/105-000 713-1415/105-000/997-408 713-1415/107-000 713-1415/116-000 713-1415/116-000/997-409 713-1415/117-000 713-1415/117-000/997-409 713-1416 713-1416/037-000 713-1416/105-000
7131410/117000, 713 1410/117 000
