Datasheet Wago 713-1407/105-000/997-406 — Даташит
Вилка под пайку THR, 2-рядн.; 0.8 x 0.8 mm solder pin; прямые; 100% защита от неправильного подсоединения; упаковка в ленте на бобине; Шаг контактов 3,5 мм; 2 x 7-полюсов
THR MALE HEADER, 2-ROW0.8 X 0.8 MM SOLDER PIN STRAIGHT, BLACK | |||
713-1407/105-000/997-406 Wago | по запросу | ||
Цвет | black |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 13.3 mm / 0.524 inch |
Fire load | 0.085 MJ |
GTIN | 4050821308584 |
Height | 15.9 mm / 0.626 inch |
Height from the surface | 13.5 mm / 0.531 inch |
Insulating material | Polyphtalamide (PPA GF) |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | Yes |
Number of Poles | 14 |
Number of levels | 2 |
PCB contact | THR |
Packaging type | bag |
Plated through-hole diameter (THR) | 1.2 (+ 0.1) мм |
Rated current | 10 A |
Rated voltage (II / 2) | 250 В |
Rated voltage (III / 3) | 80 В |
Reel diameter of tape-and-reel packaging | 330 мм |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 0.8 x 0.8 mm |
Solder pin length | 2.4 мм |
Tape width | 44 мм |
Total number of potentials | 14 |
Вес | 3.684 г |
Ширина | 26 mm / 1.024 inch |
Серия: 713 (100 из 548)
- 713-1118/037-000 713-1118/037-047 713-1118/037-047/035-000 713-1118/037-9037 713-1118/037-9037/035-000 713-1118/107-000 713-1118/107-047 713-1118/107-047/035-000 713-1118/107-9037 713-1118/107-9037/035-000 713-126 713-127 713-128 713-129 713-130 713-1403 713-1403/037-000 713-1403/105-000 713-1403/107-000 713-1403/116-000 713-1403/116-000/997-405 713-1403/117-000 713-1404 713-1404/037-000 713-1404/105-000 713-1404/107-000 713-1404/116-000 713-1404/116-000/997-406 713-1404/117-000 713-1404/117-000/997-406 713-1405 713-1405/037-000 713-1405/105-000 713-1405/107-000 713-1405/116-000 713-1405/116-000/997-406 713-1405/117-000 713-1405/117-000/997-406 713-1406 713-1406/037-000 713-1406/105-000 713-1406/105-000/997-406 713-1406/107-000 713-1406/116-000 713-1406/116-000/997-406 713-1406/117-000 713-1406/117-000/997-406 713-1407 713-1407/037-000 713-1407/105-000 713-1407/105-000/997-406 713-1407/107-000 713-1407/116-000 713-1407/116-000/997-407 713-1407/117-000 713-1407/117-000/997-407 713-1408 713-1408/037-000 713-1408/105-000 713-1408/105-000/997-406 713-1408/107-000 713-1408/116-000 713-1408/116-000/997-407 713-1408/117-000 713-1408/117-000/997-407 713-1409 713-1409/037-000 713-1409/105-000 713-1409/105-000/997-407 713-1409/107-000 713-1409/116-000 713-1409/116-000/997-407 713-1409/117-000 713-1409/117-000/997-407 713-1410 713-1410/037-000 713-1410/105-000 713-1410/105-000/997-407 713-1410/107-000 713-1410/116-000 713-1410/116-000/997-408 713-1410/117-000 713-1410/117-000/997-408 713-1411 713-1411/037-000 713-1411/105-000 713-1411/105-000/997-407 713-1411/107-000 713-1411/116-000 713-1411/116-000/997-408 713-1411/117-000 713-1411/117-000/997-408 713-1412 713-1412/037-000 713-1412/105-000 713-1412/105-000/997-408 713-1412/107-000 713-1412/116-000 713-1412/116-000/997-408 713-1412/117-000
7131407/105000/997406, 713 1407/105 000/997 406
