Datasheet Wago 713-1110/107-000 — Даташит
1-проводниковая розетка; 100% защита от неправильного подсоединения; Винтовой фланец; 1,5; Шаг контактов 3,5 мм; 20-пол.
1-CONDUCTOR FEMALE PLUG; 100% PR | |||
713-1110/107-000 Wago | 1 214 ₽ | ||
713-1110/107-000 Wago | по запросу |
Цвет | black |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 16 mm / 0.63 inch |
Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1 mm² |
Fire load | 0.157 MJ |
GTIN | 4045454806811 |
Height | 18.8 mm / 0.74 inch |
Insulating material | Glass fiber-reinforced polyamide (PA 66 GF) |
Locking of plug-in connection | Screw flange |
Material group | II |
Mismating protection | Yes |
Number of Poles | 20 |
Number of levels | 2 |
Rated current | 10 A |
Rated voltage (II / 2) | 250 В |
Rated voltage (III / 3) | 80 В |
Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
Strip length | 6 … 7 mm / 0.24 … 0.28 Inch |
Total number of connection points | 20 |
Total number of potentials | 20 |
Вес | 10.89 г |
Ширина | 45.1 mm / 1.776 inch |
Серия: 713 (100 из 548)
- 713-1107/037-000 713-1107/037-047 713-1107/037-047/033-000 713-1107/037-9037 713-1107/037-9037/033-000 713-1107/107-000 713-1107/107-047 713-1107/107-047/033-000 713-1107/107-9037 713-1107/107-9037/033-000 713-1108 713-1108/000-047 713-1108/000-9037 713-1108/033-047 713-1108/033-9037 713-1108/037-000 713-1108/037-047 713-1108/037-047/033-000 713-1108/037-9037 713-1108/037-9037/033-000 713-1108/107-000 713-1108/107-047 713-1108/107-047/033-000 713-1108/107-9037 713-1108/107-9037/033-000 713-1109 713-1109/000-047 713-1109/000-9037 713-1109/033-047 713-1109/033-9037 713-1109/037-000 713-1109/037-047 713-1109/037-047/033-000 713-1109/037-9037 713-1109/037-9037/033-000 713-1109/107-000 713-1109/107-047 713-1109/107-047/033-000 713-1109/107-9037 713-1109/107-9037/033-000 713-1110 713-1110/000-047 713-1110/000-9037 713-1110/033-047 713-1110/033-9037 713-1110/037-000 713-1110/037-047 713-1110/037-047/033-000 713-1110/037-9037 713-1110/037-9037/033-000 713-1110/107-000 713-1110/107-047 713-1110/107-047/033-000 713-1110/107-9037 713-1110/107-9037/033-000 713-1111 713-1111/000-047 713-1111/000-9037 713-1111/034-047 713-1111/034-9037 713-1111/037-000 713-1111/037-047 713-1111/037-047/034-000 713-1111/037-9037 713-1111/037-9037/034-000 713-1111/107-000 713-1111/107-047 713-1111/107-047/034-000 713-1111/107-9037 713-1111/107-9037/034-000 713-1112 713-1112/000-047 713-1112/000-9037 713-1112/034-047 713-1112/034-9037 713-1112/037-000 713-1112/037-047 713-1112/037-047/034-000 713-1112/037-9037 713-1112/037-9037/034-000 713-1112/107-000 713-1112/107-047 713-1112/107-047/034-000 713-1112/107-9037 713-1112/107-9037/034-000 713-1113 713-1113/000-047 713-1113/000-9037 713-1113/034-047 713-1113/034-9037 713-1113/037-000 713-1113/037-047 713-1113/037-047/034-000 713-1113/037-9037 713-1113/037-9037/034-000 713-1113/107-000 713-1113/107-047 713-1113/107-047/034-000 713-1113/107-9037 713-1113/107-9037/034-000
7131110/107000, 713 1110/107 000
