Клеммные колодки Keen Side
Datasheet Wago 253-107 — Даташит
Серия253
Модель253-107
Клеммная колодка для печатной платы с 2 проводниками; 1,5 мм²; Шаг контактов 5 мм; 7-полюсный; PUSH WIRE
High Performance Frequency Synthesizer System with Integrated VCO
DK-2531-07
1 621 ₽
ТаймЧипс
DK-2531-07
LMX2531_07
Actuation typeOperating tool
Цветgray
Conductor entry angle to the PCB 290 °
Connection technologyPUSH WIRE®
Connection technology 2PUSH WIRE®
Connection type (1)PUSH WIRE® connection
Connection type (2)PUSH WIRE® connection
Contact platingtin-plated
Country of originCN
Габариты: глубина12.8 mm / 0.504 inch
Fire load0.129 MJ
GTIN4044918689403
Height16.6 mm / 0.654 inch
Height from the surface13 mm / 0.512 inch
Material groupI
Note (strip length)7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides)
Note (strip length) 27 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides)
Number of Poles7
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels2
PCB contactTHT
Pin spacing5 mm (0.197 inch)
Rated current17.5 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Solder pin arrangementover the entire terminal strip, staggered
Solder pin dimensions0.5 x 0.8 mm
Solder pin length3.6 мм
Solid conductor0.5 … 1.5 mm² / 20 … 16 AWG
Solid conductor (2)0.5 … 1.5 mm² / 20 … 16 AWG
Strip length8.5 … 9.5 mm / 0.33 … 0.37 Inch
Strip length (2)8.5 … 9.5 mm / 0.33 … 0.37 Inch
Total number of connection points14
Total number of potentials7
Вес6.214 г
Ширина37 mm / 1.457 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 253-107
