Datasheet Wago 253-103/000-006 — Даташит
2-проводная клеммная колодка для печатной платы; 1,5 мм²; Расстояние между контактами 5 мм; 3-полюсный; НАЖМИТЕ ПРОВОД
2-CONDUCTOR PCB TERMINAL BLOCK; | |||
253-103/000-006 Wago | по запросу |
Цвет | blue |
Conductor entry angle to the PCB 2 | 90 ° |
Connection technology | PUSH WIRE® |
Connection technology 2 | PUSH WIRE® |
Connection type (1) | PUSH WIRE® connection |
Connection type (2) | PUSH WIRE® connection |
Country of origin | CH |
Габариты: глубина | 12.8 mm / 0.504 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fire load | 0.061 MJ |
GTIN | 4044918689212 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 13 mm / 0.512 inch |
Material group | I |
Note (strip length) | 7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides) |
Note (strip length) 2 | 7 … 8 mm / 0.28 … 0.31 in. (for wiring on both sides) |
Number of Poles | 3 |
Number of connection points | 1 |
Number of connection points (connection type) | 1 |
Number of connection types | 2 |
Number of levels | 2 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 17.5 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solder pin arrangement | over the entire terminal strip, staggered |
Solder pin dimensions | 0.5 x 0.8 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.5 … 1.5 mm² / 20 … 16 AWG |
Solid conductor (2) | 0.5 … 1.5 mm² / 20 … 16 AWG |
Strip length | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
Strip length (2) | 8.5 … 9.5 mm / 0.33 … 0.37 Inch |
Total number of connection points | 6 |
Total number of potentials | 3 |
Вес | 2.842 г |
Ширина | 17 mm / 0.669 inch |
Серия: 253 (35)
- 253-102 253-102/000-006 253-102/000-012 253-103 253-103/000-006 253-104 253-104/000-006 253-104/000-012 253-105 253-105/000-006 253-105/000-012 253-106 253-106/000-006 253-106/000-012 253-107 253-107/000-006 253-107/000-012 253-108 253-108/000-006 253-109 253-109/000-006 253-110 253-110/000-006 253-110/000-012 253-111 253-111/000-006 253-112 253-112/000-012 253-113 253-114 253-114/000-006 253-115 253-116 253-116/000-006 253-116/000-012
- PCB Interconnect
253103/000006, 253 103/000 006
