Datasheet Wago 236-406/334-604/997-406 — Даташит
Клеммная колодка THR PCB; 2,5 мм²; Шаг контактов 5 мм; 6-полюсная; CAGE CLAMP; в упаковке на ленте и катушке; возможность объединения
THR PCB TERMINAL BLOCK; 2.5 MM; | |||
236-406/334-604/997-406 Wago | по запросу |
Цвет | black |
Country of origin | DE |
Габариты: глубина | 14 mm / 0.551 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule without plastic collar | 0.25 … 1.5 mm² |
Flammability class per UL94 | V2 |
GTIN | 4055143469685 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 13 mm / 0.512 inch |
Insulating material | Polyamide 46 (PA 46) |
Limit temperature range | -60 … +115 °C |
Material group | III a |
Number of Poles | 6 |
Number of levels | 1 |
PCB contact | THR |
Pin spacing | 5 mm / 0.197 inch |
Plated through-hole diameter (THR) | 1.1 (+ 0.1) мм |
Rated current | 24 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 200 В |
Reel diameter of tape-and-reel packaging | 330 мм |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.7 x 0.7 mm |
Solder pin length | 3.6 мм |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Tape width | 44 мм |
Total number of connection points | 6 |
Total number of potentials | 6 |
Вес | 5.45 г |
Ширина | 32.3 mm / 1.272 inch |
Серия: 236 (100 из 244)
- 236-208 236-209 236-212 236-216 236-224 236-300 236-301 236-302 236-303 236-304 236-305 236-306 236-307 236-308 236-309 236-312 236-316 236-324 236-400 236-401 236-401/332-000 236-402 236-402/000-005 236-402/000-009/999-950 236-402/332-000 236-402/332-009/999-950 236-402/334-604 236-402/334-604/997-405 236-403 236-403/000-009/999-950 236-403/332-000 236-403/332-009/999-950 236-403/334-604 236-403/334-604/997-405 236-404 236-404/000-009/999-950 236-404/000-015 236-404/332-000 236-404/332-009/999-950 236-404/334-604 236-404/334-604/997-406 236-405 236-405/334-604 236-405/334-604/997-406 236-406 236-406/000-009/999-950 236-406/332-000 236-406/332-009/999-950 236-406/334-023 236-406/334-604 236-406/334-604/997-406 236-407 236-408 236-408/000-009/999-950 236-408/332-000 236-408/332-009/999-950 236-408/334-023 236-409 236-409/334-604 236-412 236-412/000-009/999-950 236-412/332-000 236-412/332-009/999-950 236-416 236-416/000-009/999-950 236-416/332-009/999-950 236-416/334-023 236-424 236-424/000-009/999-950 236-424/332-009/999-950 236-436 236-436/000-009/999-950 236-436/332-009/999-950 236-441 236-448 236-448/000-009/999-950 236-448/332-000 236-448/332-009/999-950 236-500 236-501 236-501/332-000 236-502 236-502/000-004 236-502/000-009/999-950 236-502/332-000 236-502/332-009/999-950 236-503 236-503/000-009/999-950 236-503/000-015 236-503/332-000 236-503/332-009/999-950 236-504 236-504/000-009/999-950 236-504/332-000 236-504/332-009/999-950 236-505 236-506 236-506/000-009/999-950 236-506/332-009/999-950 236-507
- PCB Interconnect
236406/334604/997406, 236 406/334 604/997 406
