Datasheet Wago 235-767/331-000 — Даташит
Серия235
Модель235-767/331-000
Стекируемый клеммный блок печатной платы; Кнопка; 1,5 мм²; Шаг контактов 10/10,16 мм; 1-полюсный; Зажим Push-in CAGE CLAMP
Actuation typePush-button
Цветlight green
Contact platingtin-plated
Country of originCH
Габариты: глубина12.5 mm / 0.492 inch
Drilled hole diameter (tolerance)1(+ 0.1) мм
Fine-stranded conductor0.75 … 1.5 mm² / 20 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 1 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 1 mm²
Fire load0.022 MJ
GTIN4044918832892
Height19.1 mm / 0.752 inch
Height from the surface15.5 mm / 0.61 inch
Material groupI
Number of Poles1
Number of connection types1
Number of levels1
PCB contactTHT
Pin spacing10/10.16 mm / 0.394/0.4 inch
Rated current17.5 A
Rated impulse voltage (II / 2)8 kV
Rated impulse voltage (III / 2)8 kV
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)1000 В
Rated voltage (III / 3)630 В
Solder pin arrangementwithin the terminal block, in line
Solder pin dimensions0.4 x 0.8 mm
Solder pin length3.6 мм
Solid conductor0.2 … 1.5 mm² / 20 … 14 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points1
Total number of potentials1
Вес1.063 г
Ширина11.5 mm / 0.453 inch
  • PCB Interconnect
235767/331000, 235 767/331 000
На английском языке: Datasheet Wago 235-767/331-000
