Datasheet Wago 232-842/047-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; Проходной фланец; Шаг контактов 7,5 мм; 12-пол.
THT FEMALE HEADER; 0.6 X 1.0 MM | |||
232-842/039-000 Wago | по запросу | ||
232-842 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 18.25 mm / 0.719 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
Fire load | 0.276 MJ |
GTIN | 4050821638100 |
Height | 16.6 mm / 0.654 inch |
Height from the surface | 11.6 mm / 0.457 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Mounting flange |
Number of Poles | 12 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 12 |
Type of mounting | Flush mounting Panel mounting |
Вес | 14.108 г |
Ширина | 97.3 mm / 3.831 inch |
Серия: 232 (100 из 896)
- 232-832/045-000 232-832/047-000 232-833 232-833/031-000 232-833/039-000 232-833/045-000 232-833/047-000 232-834 232-834/031-000 232-834/039-000 232-834/045-000 232-834/047-000 232-835 232-835/031-000 232-835/039-000 232-835/047-000 232-836 232-836/031-000 232-836/039-000 232-836/045-000 232-836/047-000 232-837 232-837/031-000 232-837/039-000 232-837/045-000 232-837/047-000 232-838 232-838/031-000 232-838/039-000 232-838/045-000 232-838/047-000 232-839 232-839/031-000 232-839/039-000 232-839/045-000 232-839/047-000 232-840 232-840/031-000 232-840/039-000 232-840/045-000 232-840/047-000 232-841 232-841/031-000 232-841/039-000 232-841/045-000 232-841/047-000 232-842 232-842/031-000 232-842/039-000 232-842/045-000 232-842/047-000 232-843 232-843/031-000 232-843/039-000 232-843/045-000 232-843/047-000 232-844/045-000 232-845/045-000 232-846 232-846/031-000 232-846/039-000 232-846/045-000 232-846/047-000 232-862 232-862/031-000 232-862/039-000 232-862/045-000 232-862/047-000 232-863 232-863/031-000 232-863/039-000 232-863/045-000 232-863/047-000 232-864 232-864/031-000 232-864/039-000 232-864/045-000 232-864/047-000 232-865 232-865/031-000 232-865/039-000 232-865/045-000 232-865/047-000 232-866 232-866/031-000 232-866/039-000 232-866/045-000 232-866/047-000 232-867 232-867/031-000 232-867/039-000 232-867/045-000 232-867/047-000 232-868 232-868/031-000 232-868/039-000 232-868/045-000 232-868/047-000 232-869 232-869/031-000
232842/047000, 232 842/047 000
