Источники питания Keen Side
Datasheet Wago 232-836/031-000 — Даташит
Серия232
Модель232-836/031-000
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; угловые; зажимное кольцо; Шаг контактов 7,5 мм; 6-пол.
Wire-board; socket; female; PIN:6; 7.5mm; angled 90°; latch; tinned
219 ₽
261 ₽
МосЧип
Littelfuse
Цветgray
Contact materialCopper alloy
Contact platingtin-plated
Country of originDE
Габариты: глубина18.25 mm / 0.719 inch
Drilled hole diameter (tolerance)1.3(+ 0.1) мм
Fire load0.141 MJ
GTIN4044918626392
Height16.6 mm / 0.654 inch
Height from the surface11.6 mm / 0.457 inch
Material groupI
Mismating protectionNo
Mounting typeMounting flange
Number of Poles6
Number of levels1
PCB contactTHT
Pin spacing7.5 mm (0.295 inch)
Rated current12 A
Rated voltage (II / 2)1000 В
Rated voltage (III / 2)630 В
Rated voltage (III / 3)500 В
Solder pin arrangementover the entire female connector, in line
Solder pin dimensions0.6 x 1 mm
Solder pin length5 мм
Total number of potentials6
Type of mountingFeed-through mounting Panel mounting
Вес7.124 г
Ширина57.3 mm / 2.256 inch
232836/031000, 232 836/031 000
На английском языке: Datasheet Wago 232-836/031-000
