Datasheet Wago 232-739/039-000 — Даташит
Розетка под пайку THT; 0.6 x 1.0 mm solder pin; прямые; Фиксирующий рычаг; Шаг контактов 7,5 мм; 9-пол.
THT FEMALE HEADER; 0.6 X 1.0 MM | |||
232-739 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 11.6 mm / 0.457 inch |
Drilled hole diameter (tolerance) | 1.3(+ 0.1) мм |
GTIN | 4055143759861 |
Height | 23.25 mm / 0.915 inch |
Height from the surface | 18.25 mm / 0.719 inch |
Limit temperature range | -60 … +85 °C |
Locking of plug-in connection | locking lever |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 9 |
Number of levels | 1 |
PCB contact | THT |
Packaging type | BOX |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solder pin arrangement | over the entire female connector, in line |
Solder pin dimensions | 0.6 x 1 mm |
Solder pin length | 5 мм |
Total number of potentials | 9 |
Вес | 10.72 г |
Ширина | 80.8 mm / 3.181 inch |
Серия: 232 (100 из 896)
- 232-642 232-646 232-662 232-663 232-664 232-665 232-667 232-670 232-682 232-683 232-684 232-685 232-687 232-732 232-732/031-000 232-732/039-000 232-732/045-000 232-732/047-000 232-733 232-733/031-000 232-733/039-000 232-733/045-000 232-733/047-000 232-734 232-734/031-000 232-734/039-000 232-734/045-000 232-734/047-000 232-735 232-735/031-000 232-735/039-000 232-735/045-000 232-735/047-000 232-736 232-736/031-000 232-736/039-000 232-736/045-000 232-736/047-000 232-737 232-737/031-000 232-737/039-000 232-737/045-000 232-737/047-000 232-738 232-738/031-000 232-738/039-000 232-738/045-000 232-738/047-000 232-739 232-739/031-000 232-739/039-000 232-739/045-000 232-739/047-000 232-740 232-740/031-000 232-740/039-000 232-740/045-000 232-740/047-000 232-741 232-741/031-000 232-741/039-000 232-741/045-000 232-741/047-000 232-742 232-742/031-000 232-742/039-000 232-742/045-000 232-742/047-000 232-743 232-743/031-000 232-743/039-000 232-743/045-000 232-743/047-000 232-744/045-000 232-745/045-000 232-746 232-746/031-000 232-746/039-000 232-746/045-000 232-746/047-000 232-762 232-762/031-000 232-762/039-000 232-762/045-000 232-762/047-000 232-763 232-763/031-000 232-763/039-000 232-763/045-000 232-763/047-000 232-764 232-764/031-000 232-764/039-000 232-764/045-000 232-764/047-000 232-765 232-765/031-000 232-765/039-000 232-765/045-000 232-765/047-000
232739/039000, 232 739/039 000
