Datasheet Wago 232-551/007-000 — Даташит
Штекерная часть электрического соединителя с двумя выводами; DIN-35 rail mounting; Шаг контактов 5,08 мм; 21-пол.
DOUBLE PIN HEADER; DIN-35 RAIL M | |||
232-551/007-000 Wago | по запросу |
Цвет | orange |
Connector connection type | for pluggable connectors |
Country of origin | DE |
Габариты: глубина | 42.5 mm / 1.673 inch |
Fire load | 0.369 MJ |
GTIN | 4045454340186 |
Height from upper-edge of DIN-35 rail | 15 mm / 0.591 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 21 |
Number of levels | 1 |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 12 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Ratings note | Notice: Male connectors shall not be live when disconnected! |
Total number of potentials | 21 |
Type of mounting | DIN-35 rail |
Вес | 18.438 г |
Ширина | 109.88 mm / 4.326 inch |
Серия: 232 (100 из 896)
- 232-417/026-000 232-418/026-000 232-419/026-000 232-420/026-000 232-421/026-000 232-422/026-000 232-423/026-000 232-424/026-000 232-502/007-000 232-503/007-000 232-504/007-000 232-505/007-000 232-506/007-000 232-507/007-000 232-508/007-000 232-509/007-000 232-510/007-000 232-511/007-000 232-512/007-000 232-513/007-000 232-514/007-000 232-515/007-000 232-516/007-000 232-517/007-000 232-518/007-000 232-519/007-000 232-520/007-000 232-521/007-000 232-522/007-000 232-523/007-000 232-524/007-000 232-532/007-000 232-533/007-000 232-534/007-000 232-535/007-000 232-536/007-000 232-537/007-000 232-538/007-000 232-539/007-000 232-540/007-000 232-541/007-000 232-542/007-000 232-543/007-000 232-544/007-000 232-545/007-000 232-546/007-000 232-547/007-000 232-548/007-000 232-549/007-000 232-550/007-000 232-551/007-000 232-552/007-000 232-553/007-000 232-554/007-000 232-562/007-000 232-563/007-000 232-564/007-000 232-565/007-000 232-566/007-000 232-567/007-000 232-568/007-000 232-569/007-000 232-570/007-000 232-571/007-000 232-572/007-000 232-582/007-000 232-583/007-000 232-584/007-000 232-585/007-000 232-586/007-000 232-587/007-000 232-588/007-000 232-589/007-000 232-590/007-000 232-591/007-000 232-592/007-000 232-602 232-603 232-604 232-605 232-606 232-607 232-608 232-609 232-610 232-612 232-632 232-633 232-634 232-635 232-636 232-637 232-638 232-639 232-640 232-642 232-646 232-662 232-663 232-664
232551/007000, 232 551/007 000
