Datasheet Wago 232-305/026-000 — Даташит
1-проводниковая розетка; угловые; 2,5 мм²; Шаг контактов 5,08 мм; 5-пол.
1-CONDUCTOR FEMALE PLUG; ANGLED; | |||
232-305/026-000 Wago | по запросу |
Цвет | orange |
Conductor entry direction to mating direction | 270 ° |
Contact material | Copper alloy |
Country of origin | PL |
Габариты: глубина | 22.75 mm / 0.896 inch |
Design | angled |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.153 MJ |
GTIN | 4044918385398 |
Height | 23.9 mm / 0.941 inch |
Material group | I |
Mismating protection | No |
Number of Poles | 5 |
Number of levels | 1 |
Pin spacing | 5.08 mm (0.2 inch) |
Rated current | 14 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 5 |
Total number of potentials | 5 |
Вес | 9.401 г |
Ширина | 27.8 mm / 1.094 inch |
Серия: 232 (100 из 896)
- 232-273/031-000 232-273/039-000 232-273/047-000 232-274 232-274/031-000 232-274/039-000 232-274/047-000 232-275 232-275/031-000 232-275/039-000 232-275/047-000 232-276 232-276/031-000 232-276/039-000 232-276/047-000 232-277 232-277/031-000 232-277/039-000 232-277/047-000 232-278 232-278/031-000 232-278/039-000 232-278/047-000 232-279 232-279/031-000 232-279/039-000 232-279/047-000 232-280 232-280/031-000 232-280/039-000 232-280/047-000 232-281 232-281/031-000 232-281/039-000 232-281/047-000 232-282 232-282/031-000 232-282/039-000 232-282/047-000 232-283 232-283/031-000 232-283/039-000 232-283/047-000 232-284 232-284/031-000 232-284/039-000 232-284/047-000 232-302/026-000 232-303/026-000 232-304/026-000 232-305/026-000 232-306/026-000 232-307/026-000 232-308/026-000 232-309/026-000 232-310/026-000 232-311/026-000 232-312/026-000 232-313/026-000 232-314/026-000 232-315/026-000 232-316/026-000 232-317/026-000 232-318/026-000 232-319/026-000 232-320/026-000 232-321/026-000 232-322/026-000 232-323/026-000 232-324/026-000 232-332 232-333 232-334 232-335 232-336 232-337 232-338 232-340 232-342 232-346 232-362 232-363 232-364 232-366 232-368 232-370 232-372 232-376 232-402/026-000 232-403/026-000 232-404/026-000 232-405/026-000 232-406/026-000 232-407/026-000 232-408/026-000 232-409/026-000 232-410/026-000 232-411/026-000 232-411/026-000/035-000 232-412/026-000
232305/026000, 232 305/026 000
